Question: Plotting a Spline
Hello, Mapleprimes' users.
I am using spline to fit a function to a given data (instead of polynomial). I created two examples with data of y=cos(x).
The first example has a domain X=0..10 and its result is satisfactory.
Ths second example has a larger domain, X=0..15, but I couldn't plot the spline function. The function fits well, but its line ends at X=~10.
Then I ckecked this spline assigning several values of X, and all the results are correct. The problem is on the plot step.
My mw file is:
> restart;
> with(plots);
> with(CurveFitting);
> plotsetup(default);
First Exemple Data (Y=cos(X)):
> X := [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10];
> Y := [1, .54, -.41, -.99, -.65, .28, .96, .75, -.14, -.91, -.83];
> Piece1 := spline(X, Y, x, 2);
> fig1 := plot(Piece1, view = [0 .. 15, -1 .. 1]);
> fig2 := pointplot(X, Y);
> display(fig1, fig2);
_ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
Second Example Data (Y=cos(X))::
> X := [0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15];
> Y := [1, .54, -.41, -.99, -.65, .28, .96, .75, -.14, -.91, -.83, 0., .84, .91, .13, -.76];
> Piece2 := spline(X, Y, x, 2);
> fig3 := plot(Piece2, view = [0 .. 15, -1 .. 1]);
> fig4 := pointplot(X, Y);
> display(fig3, fig4);
> test := unapply(Piece2, x);
> test(15);
    test(15)=-0.76    #correct value!
My actual problem involves data from X=0 to X=300, and I have the same issue in this case.
Thanks.
