Question: how to call a procedure using named parameter binding in Maple?
I could not find a way to do this in Maple looking at http://www.maplesoft.com/support/help/Maple/view.aspx?path=parameter_classes
and I see that Maple is missing from http://rosettacode.org/wiki/Named_parameters
Is it possible to call a Maple proc using named parameters? Here is an example of what this looks like from a small Ada example from the above link:
procedure Foo (Arg_1 : Integer; Arg_2 : Float := 0.0);
Foo (Arg_2 => 0.0, Arg_1 => 1);
This is very useful for proc with many arguments, and it also makes the code much
more clear and less change in using the wrong value for the wrong parameter.
In Maple notation, this can be like
foo:=proc(arg1::integer,arg2::float) ..... end proc;
foo(arg2=>10,arg1=>200);
(This editor is so bad, can't someone fix it?)
