Question: Error with function using Units
Please see the attached worksheet for the error at the end, any idea what happens?
Besides, anyone know how to make plot array with each element has a plot and scatterplot in it?  I made my plot by making table first and then type the cmd individually.
Raw Data
avicel102_aero200 := Matrix(12, 3, {(1, 1) = 50, (1, 2) = 1.6621, (1, 3) = .22, (2, 1) = 100, (2, 2) = 3.33221, (2, 3) = .103, (3, 1) = 150, (3, 2) = 4.95533, (3, 3) = 0.43e-1, (4, 1) = 200, (4, 2) = 5.62147, (4, 3) = 0.37e-1, (5, 1) = 50, (5, 2) = 1.88627, (5, 3) = .207, (6, 1) = 50, (6, 2) = 1.90375, (6, 3) = .199, (7, 1) = 100, (7, 2) = 4.04708, (7, 3) = 0.89e-1, (8, 1) = 100, (8, 2) = 4.20413, (8, 3) = 0.87e-1, (9, 1) = 150, (9, 2) = 5.50509, (9, 3) = 0.41e-1, (10, 1) = 150, (10, 2) = 4.90453, (10, 3) = 0.49e-1, (11, 1) = 200, (11, 2) = 6.22001, (11, 3) = 0.16e-1, (12, 1) = 200, (12, 2) = 6.24435, (12, 3) = 0.23e-1}); avicel102_syloid := Matrix(13, 3, {(1, 1) = 50, (1, 2) = 1.76578, (1, 3) = .235, (2, 1) = 100, (2, 2) = 4.08314, (2, 3) = .128, (3, 1) = 150, (3, 2) = 4.85921, (3, 3) = 0.73e-1, (4, 1) = 200, (4, 2) = 5.66786, (4, 3) = 0.51e-1, (5, 1) = 50, (5, 2) = 2.06221, (5, 3) = .224, (6, 1) = 50, (6, 2) = 2.17294, (6, 3) = .216, (7, 1) = 100, (7, 2) = 4.03728, (7, 3) = .109, (8, 1) = 100, (8, 2) = 3.67978, (8, 3) = .116, (9, 1) = 150, (9, 2) = 5.78427, (9, 3) = 0.6e-1, (10, 1) = 150, (10, 2) = 5.43599, (10, 3) = 0.59e-1, (11, 1) = 200, (11, 2) = 6.26332, (11, 3) = 0.38e-1, (12, 1) = 200, (12, 2) = 6.10814, (12, 3) = 0.39e-1, (13, 1) = 200, (13, 2) = 6.83857, (13, 3) = 0.25e-1}); avicel301_101_aero200 := Matrix(12, 3, {(1, 1) = 50, (1, 2) = 1.106, (1, 3) = .2597543205, (2, 1) = 50, (2, 2) = 1.06, (2, 3) = .2564849561, (3, 1) = 50, (3, 2) = 1.129, (3, 3) = .2552025392, (4, 1) = 100, (4, 2) = 2.865, (4, 3) = .1280363098, (5, 1) = 100, (5, 2) = 2.793, (5, 3) = .127659333, (6, 1) = 100, (6, 2) = 3.088, (6, 3) = .1347147061, (7, 1) = 150, (7, 2) = 4.216, (7, 3) = 0.802489497e-1, (8, 1) = 150, (8, 2) = 4.044, (8, 3) = 0.838493001e-1, (9, 1) = 150, (9, 2) = 4.071, (9, 3) = 0.855901289e-1, (10, 1) = 200, (10, 2) = 4.826, (10, 3) = 0.627298821e-1, (11, 1) = 200, (11, 2) = 4.924, (11, 3) = 0.614759445e-1, (12, 1) = 200, (12, 2) = 4.76, (12, 3) = 0.61001365e-1})
with(LinearAlgebra):
X[1] := Column(avicel102_aero200, 3):
X[2] := Column(avicel102_syloid, 3):
X[3] := Column(avicel301_101_aero200, 3):
S := Array(1 .. 3):
S[1] := ScatterPlot(X[1], Y[1], labels = [Porocity, Tensile*Strength], title = Compactability*of*Avicel102*with*Aerosil200):
with(plots):NULL
vSST := Array(1 .. 3):
tpfit := proc (x, y) options operator, arrow; Fit(a*exp(-k*p)+c, x, y, p, output = [leastsquaresfunction, residualsumofsquares, degreesoffreedom]) end proc:SST := proc (y) options operator, arrow; Variance(y)*(NumElems(y)-1) end proc:NULL
for i to 3 do fnTP[i] := tpfit(X[i], Y[i])[1] end do:
for i to 3 do fnPC[i] := Fit(c*p^2+b*p+a, P[i], X[i], p, output = [leastsquaresfunction, residualsumofsquares, degreesoffreedom])[1] end do:
for i to 3 do vSST[i] := SST(Y[i]) end do:
for i to 3 do pSST[i] := SST(X[i]) end do:
for i to 3 do vSSR[i] := tpfit(X[i], Y[i])[2] end do:
for i to 3 do Rsquare[i] := 1-vSSR[i]/vSST[i] end do:
s := Array(1 .. 3):
for i to 3 do s[i] := plot(fnTP[i], p = 0 .. .26, legend = typeset(fnTP[i], R^2, "= ", Rsquare[i])) end do
for i to 3 do ps[i] := plot(fnPC[i], p = 0 .. 200, legend = typeset(fnPC[i], R^2, "= ", pRsquare[i])) end do
G := Array(1 .. 3):
G[1] := [S[1], s[1]]:
pG := [[PS[1], ps[1]], [PS[2], ps[2]], [PS[3], ps[3]]]:NULL
Table 1: Compactability Curve
display(G[1])
display(G[2])
display(G[3])
Table 2: Compressibility Curve
display(pG[1])
display(pG[2])
display(pG[3])
ff := proc (x) options operator, arrow; unapply(x, p) end proc:
gtp := map(ff, fnTP):
gpc := map(ff, fnPC):
TS1 := proc (pressure) options operator, arrow; (`@`(gtp[1], gpc[1]))(pressure/Unit('MPa'))*Unit('MPa') end proc:
TS2 := proc (pressure) options operator, arrow; (`@`(gtp[2], gpc[2]))(pressure/Unit('MPa'))*Unit('MPa') end proc:
TS3 := proc (pressure) options operator, arrow; (`@`(gtp[3], gpc[2]))(pressure/Unit('MPa'))*Unit('MPa') end proc:
por1 := proc (p) options operator, arrow; gpc[1](p/Unit('MPa')) end proc:
por1(x*Unit('MPa'))
HFloat(0.36333333333333295)-HFloat(0.0036139999999999957)*x+HFloat(9.666666666666651e-6)*x^2
por1(x);
HFloat(0.36333333333333295)-HFloat(0.0036139999999999957)*x/Units:-Unit('MPa')+HFloat(9.666666666666651e-6)*x^2/Units:-Unit('MPa')^2
ts := 2/3*(10*P/(Pi*D^2*(2.84*t/D-.126*t/W+3.15*W/D+0.1e-1))):
Target Weight of Tablet, m__t:
m__t := 700*Unit('mg')
700*Units:-Unit('mg')
Tablet True Density:NULL
`ρ__true1` := 1.8*Unit('g'/'cm'^3)
1800.0*Units:-Unit(('kg')/('m')^3)
Width of tablet w;
d := 7.747*Unit('mm')
7.747*Units:-Unit('mm')
Length of tablet, l:
l := 17.018*Unit('mm')
17.018*Units:-Unit('mm')
Cup Depth, h:
hh := 1.6764*Unit('mm')
1.6764*Units:-Unit('mm')
Cup Volume", `v__cup`"
v__cup := 119.789438*Unit('mm'^3)
119.789438*Units:-Unit(('mm')^3)
Die cross sectional area, v__die:
a__die := 118.9610524*Unit('mm'^2)
118.9610524*Units:-Unit(('mm')^2)
Equation to solve tablet thickness using tablet dimension and porocity:
Tablet bulk density:
`ρ__bulk` := `ρ__true`*sf
`ρ__true`*sf
Tablet volume:``
V__tablet := 2*V__cup+A__die*(t-2*H)
Tablet bulk Density:``
`ρ__bulk` := m__tablet/V__tablet
m__tablet/(2*V__cup+A__die*(t-2*H))
(14)
eq1 := m__tablet/(2*V__cup+A__die*(t-2*H)) = `ρ__true`*sf
(15)
Function for thickness:
thickness := unapply(simplify(solve(eq1, t), size), sf, A__die, H, V__cup, `ρ__true`, m__tablet)
proc (sf, A__die, H, V__cup, `ρ__true`, m__tablet) options operator, arrow; (2*sf*(A__die*H-V__cup)*`ρ__true`+m__tablet)/(A__die*sf*`ρ__true`) end proc
(16)
simplify(thickness(1-por[1](100*Unit(MPa)), a__die, hh, v__cup, `ρ__true1`, m__t))
HFloat(0.005719286791216391)*Units:-Unit('m')
(17)
t2 := proc (cc, A__die, H, V__cup, `ρ__true`, m__tablet) options operator, arrow; simplify(thickness(1-cc, A__die, H, V__cup, `ρ__true`, m__tablet)) end proc:
Tablet tensile strength:NULL
eq2 := `σ__t` = ts
`σ__t` = (20/3)*P/(Pi*D^2*(2.84*t/D-.126*t/W+3.15*W/D+0.1e-1))
(18)
Break force of tablet (N)
breakforce := unapply(subs(W = t-2*h, solve(eq2, P)), `σ__t`, D, h, t)
proc (`σ__t`, D, h, t) options operator, arrow; 0.9424777961e-3*`σ__t`*D*(5.*D*(t-2*h)-63.*t*D+1575.*(t-2*h)^2+1420.*t*(t-2*h))/(t-2*h) end proc
(19)
kp := simplify(breakforce(TS[1](100*Unit('MPa')), d, hh, 0.5719e-2*Unit('m')))
HFloat(286.99924404612904)*Units:-Unit('N')
(20)
convert(kp, units, kilopond)
HFloat(29.265778226624693)*Units:-Unit('kilopond')
(21)
t2(por[1](100*Unit('MPa')), a__die, hh, v__cup, `ρ__true1`, m__t)
(22)
hh
(23)
simplify(breakforce(TS[1](100*Unit('MPa')), d, hh, t2(por[1](100*Unit('MPa')), a__die, hh, v__cup, `ρ__true1`, m__t)))
HFloat(287.02451456724083)*Units:-Unit('N')
(24)
Encounter problem while chaning variable
 BF:=
proc (`σ__t`, D, p, A__die, hhh, V__cup, `ρ__true`, m__tablet) options operator, arrow; breakforce(`σ__f`, D, hhh, t2(p, A__die, hhh, V__cup, `ρ__true`, m__tablet)) end proc:
BF(TS1(100*Unit('MPa')), d, por1(100*Unit('MPa')), a__die, hh, v__cup, `ρ__true1`, m__t)
BF(HFloat(3.6712504621161846)*Units:-Unit('MPa'), 7.747*Units:-Unit('mm'), HFloat(0.09859999999999991), 118.9610524*Units:-Unit(('mm')^2), 1.6764*Units:-Unit('mm'), 119.789438*Units:-Unit(('mm')^3), 1420.00*Units:-Unit(('kg')/('m')^3), 667*Units:-Unit('mg'))
(25)
evalf(TS[1](100*Unit(MPa)))
(26)
plot(breakforce(TS1(x), d, hh, t2(por1(x), a__die, hh, v__cup, `ρ__true1`, m__t)), x = Unit('MPa') .. 200*Unit('MPa'), useunits = true)
Error, (in Units:-Standard:-+) the units `1` and `1/MPa` have incompatible dimensions
plot(t2(por1(x), a__die, hh, v__cup, `ρ__true1`, m__t), x = Unit('MPa') .. 200*Unit('MPa'), useunits = true)
plot(evalf(por1(xx)), xx = 10 .. 200)
but por1 works fine on its own with units
por1(Units:-Standard:-`*`(200, Unit('MPa')))
HFloat(0.02719999999999989)
(27)
plot(evalf(por1(xx)), xx = 10 .. 200);
Unloading Units:-Standard
Fitting_worksheet.mw
I also used a lot for for loop in this worksheet, can anyone suggest another way of doing it? And I think I initiated many Array(1..3) that is of no use.  But if I do not initiate and do the following
A[1]:=a :
A[2]:=b:
A[3]:=c:
A;
output: A
Only if I initiate A:=Array(1..3) and then define the element I can see the complete A array at the end.
