Question: Solve taking forever then not finding a solution
Hi MaplePrime-ers,
I'm using the following piece of code to (i) solve the system of symbolically, so I can (ii) evaluate equations quickly at many points of time.  This works quite well for 4 defined values, but I'm having problems adding a 5th defined value.  Specifically, solve leaves the "solution may be lost" message after taking forever.  As the symbolic solution will be run mulitple times by a optimziation algorithm, I'd ideally like to get the solve time under 2 minutes.  I've attached both executed worksheets.  Is there anything I can do to have solve work as I intend?
This first code snippet achieves what I would like to do Series_noGear.mw:
#Interconnection Equations
eq2[1] := FD_T + EM2_T = 0;
eq2[2] := ICE_T + GEN_T = 0;
eq2[3] := EM2_A + GEN_A + BAT_A = 0;
eq2[4] := -FD_W + EM2_W = 0;
eq2[5] := -ICE_W + GEN_W = 0;
eq2[6] := -EM2_V + GEN_V = 0;
eq2[7] := -EM2_V + BAT_V = 0;
#ICE
eq_c[1] := ICE_mdot_g= ICE_T * ICE_W;
#BAT
eq_c[2] := BAT_V = 271;
#EM2
EM2_ReqPow_eq := (-148.3) + (4.267)*abs(EM2_W) + (12.77)*abs(EM2_T) + (-0.0364)*abs(EM2_W)^2 + ( 1.16)*abs(EM2_W)*abs(EM2_T) + (-0.258)*abs(EM2_T)^2 + ( 0.0001181)*abs(EM2_W)^3 + (-0.0005994)*abs(EM2_W)^2*abs(EM2_T) + ( 0.0001171)*abs(EM2_W)*abs(EM2_T)^2 + (0.001739 )*abs(EM2_T)^3 + (-1.245e-07 )*abs(EM2_W)^4 + ( 1.2e-06)*abs(EM2_W)^3*abs(EM2_T) + ( -1.584e-06)*abs(EM2_W)^2*abs(EM2_T)^2 + ( 4.383e-07)*abs(EM2_W)*abs(EM2_T)^3 + (-2.947e-06)*abs(EM2_T)^4;
eq_c[3] := EM2_P = piecewise( EM2_T * EM2_W = 0, 0, EM2_W*EM2_T < 0,-1 * EM2_ReqPow_eq, EM2_ReqPow_eq);
eq_c[4] := EM2_A = EM2_P/EM2_V;
#GEN
GEN_ReqPow_eq:= (-5.28e-12) + ( 3.849e-14)*abs(GEN_W) + (-71.9)*abs(GEN_T) + (-1.168e-16)*abs(GEN_W)^2 +(1.296)*abs(GEN_W)*abs(GEN_T) + (2.489)*abs(GEN_T)^2 + (1.451e-19)*abs(GEN_W)^3 + (0.0001326)*abs(GEN_W)^2*abs(GEN_T) + (-0.008141)*abs(GEN_W)*abs(GEN_T)^2 + (-0.004539)*abs(GEN_T)^3 +(-6.325e-23)*abs(GEN_W)^4 + (-2.091e-07)*abs(GEN_W)^3*abs(GEN_T) + ( 3.455e-06)*abs(GEN_W)^2*abs(GEN_T)^2 + ( 2.499e-05)*abs(GEN_W)*abs(GEN_T)^3 + (-5.321e-05)*abs(GEN_T)^4;
eq_c[5] := GEN_P = piecewise(GEN_T * GEN_W = 0, 0, GEN_W*GEN_T < 0,-1 * GEN_ReqPow_eq, GEN_ReqPow_eq);
eq_c[6] := GEN_A = GEN_P/GEN_V;
#assumptions
assume(BAT_V::nonnegative);
assume(FD_W::nonnegative);
termeqs := {eq_c[1],eq_c[2],eq_c[3],eq_c[4],eq_c[5],eq_c[6]};
sys_eqs2 := termeqs union convert(eq2,set);
drivers2:= {ICE_T,ICE_W,FD_T,FD_W};
symvarnames2:=select(type,indets(convert(sys_eqs2,list)),name);
notdrivers2:=symvarnames2 minus drivers2;
sol2:=solve(sys_eqs2,notdrivers2) assuming real;
symb_sol2:=unapply(sol2,[drivers2[]]);
symb_sol2(1,2,3,5);
#Enumerate (there will generally be about 40, not 3)
count := 0;
for i1 from 1 to 3 do
     for i2 from 1 to 3 do
          for i3 from 1 to 3 do
               for i4 from 1 to 3 do
                    count := count + 1;
                    solsol2(count) := symb_sol2(i1,i2,i3,i4);
               od;
          od;
     od;
od;
count;
This second code snippet includes the changes in bold, which make solve take forever Series_addGear.mw:
eq2[2] := ICE_T + GBb_T = 0;
eq2[5] := -ICE_W + GBb_W = 0;
eq2[8] := GBa_T + GEN_T = 0;
eq2[9] := -GBa_W + GEN_W = 0;
#ICE
#BAT
#EM2
#GEN
#GB
eq_c[7] := GBb_T = -1/GB_R * GBa_T;
eq_c[8] := GBb_W = GB_R * GBa_W;
assume(GB_R::nonnegative);
termeqs := {eq_c[1],eq_c[2],eq_c[3],eq_c[4],eq_c[5],eq_c[6],eq_c[7],eq_c[8]};
drivers2:= {GB_R,ICE_T,ICE_W,FD_T,FD_W};
Does assume make solve work faster, or just complicate things?  Any help is greatly appreciated!
Series_addGear.mw
Series_noGear.mw
