Question: Can I take a quick peek?
I  often find mself in the following quandry: I am investigating a problem, I do a few examples, run a do loop for j from1 to 5 to see if that works and then enter
for j from 1 to 200 do  a[j]:=blah, blah,...  end do:
and 15 minutes later nothing has happened. Is the loop finishing up with j = 198 or so or is it stuck at j = 23 and it will take forever to finish? Or perhaps there is an error that turns up for j > 23?
When I think about it I can insert a print(j) command to keep track of this but there are other situations where that doesn't work. For example,
Order := 35; mtaylor(....
When nothing happens is that because the calculation is almost done? or stuck? etc.
Is it possible to take a quick peek at the state of Maple and the decide whtether to continue the computation or abort? If the calculation of mtaylor(... is particularly long I might settle for the 15 coeficients computed so far rather than abort. Can I get at those?
Any advice?
