Question: function defined, display numeric Value
I have these lines in my code, the function alpha:=(m,n,1)->...... is defined in the last line of the code below, but when I want to calculate alpah(1,1,1), there is no numeric value. Why????  Many thinks
with(LinearAlgebra):
with(plots):
with(PDEtools):
with(IntegrationTools):
interface(rtablesize=20):
d:=1: N:=2: a:=1: h:=a/N:
Kernel(x,y):=ln(abs(x-y)):
 eq2:=int(Kernel(x,y)*phi(y),y=-a..a)=sum(int(Kernel(x,y)*phi(y),y=n*h..(n+d)*h),n=-N..N-d):
Approximate the integral
eq3:=phi->int(Kernel(x,y)*phi(y),y=n*h..(n+d)*h)=add(beta[i,n]*phi((n+i-1)*h),i=1..d+1):
eq4:=int(Kernel(x,y)*phi(y),y=n*h..(n+d)*h)=add(alpha[m,n,i]*phi((n+i-1)*h),i=1..d+1):
Compute the coefficients  beta[i]
Vct_basis:=[seq(x^i,i=0..d+1)]:
fct:=[seq(unapply(Vct_basis[i],x),i=1..d+2)]:
sys:=[seq(eq3(fct[i]),i=1..d+1)]:
x:=m*h:
w := [seq(beta[i,n],i=1..d+1)]:
M,b := GenerateMatrix(sys,w):
M1:=-M: V:=-b:
Vect_beta:=(M1)^(-1).V:# Vect_beta is a vector.
beta[1]:=Vect_beta[1]:
alpha1:=(n,m)->beta[1];
(n, m) -> beta[1]
alpaha(1,1);
                                alpaha(1, 1)  ??????????????????? No numeric result
