Question: How to select two lines (not perpendicular) from a list?
I want to find a point has coordinates are integer numbers and write the equation of tangent line to a given circle,  knowing that, the points of tangent has also integer coordinates. For example, the circle has centre M(-1,-5) and radius R=5. I tried
with(geometry):
point(M,-1,-5):
R:=5:
eqS:=Equation(circle(S,(a-HorizontalCoord(M))^2 + (b-VerticalCoord(M))^2 -R^2=0,[a,b],'centername'=T)):
L:=[]:
for a from -50 to 50  do
for b from -50 to 50  do
if  a <>HorizontalCoord(M) and b<>VerticalCoord(M) and eqS then
L:=[op(L), [a,b]] fi;
od: od:
nops(L);
eqS:=Equation(circle(S,(x-HorizontalCoord(M))^2 + (y-VerticalCoord(M))^2 -R^2=0,[x,y],'centername'=T));
k:=[seq](sort(Equation(TangentLine(P, S, point(A, pt[])), [x,y])), pt in L):
seq([L[i],k[i]],i=1..nops(L));
Next,
> with(combinat):
d:=choose(k,2):
for i from 1 to nops(d) do
seq([d[i],solve([op(1,d[i]),op(2,d[i])],[x,y])],i=1..nops(d));
end do;
If I want to the point of intersection of two lines which are not perpendicular line, for example
[[-3*x-4*y-48 = 0, 4*x+3*y-6 = 0], [[x = 24, y = -30]]]
How can I select?
