Question: How to Correctly Define Elements of a Matrix Using a Function?
I'm used to Mathcad, and I am very new to Maple. Something I cannot figure out right now is how to define multiple elments of a matrix using a function.
Input Data
Define system dimensions as n:=2;
i:=1..n;
j:=1..n;
lambda:=Matrix(n);
Lambda:=Matrix(n);
upsilon:=vector(n);
Minor side note: I originaly had upsilon defined using the syntax "Vector[row](ncomp)", but this was giving me an 'exponentiation' operation error, so I changed it to what it is now (basically a list/array, which I guess has different type definitions that no longer cause the error?).
lambda[1,2]:=471.0433;
lambda[2,1]:=883.7530;
upsilon[1]:=58.69;
upsilon[2]:=18.07;
The Problem I'm Having
Now I just want to define Lambda using a function to define all elements (like I would in Mathcad).
Lambda[i,j]:= (upsilon[j]/upsilon[i]) * exp (-lambda[i,j]/2853);
which gives me an extremely long error message:
Error, invalid input: exp expects its 1st argument, x, to be of type algebraic, but received Matrix(2, 2, {(1, 1) = -0.3504976272e-3, (1, 2) = -.16509955895845776, (2, 1) = -.30975332953088164, (2, 2) = -0.3504976272e-3}, datatype = float[8]
As far as I can tell (keep in mind that this is my very first Maple project) that it doesn't like lambda as a matrix? But shouldn't it just evaluate to the element? and why is (2,2) and (1,1) giving values, because it should intialize to zero, so exp(0) = 1 in these cases??
I tried to simplify further by just trying
Lambda[i,j]:=(upsilon[j]/upsilon[i]);
but then it just gives me 1, and when I look into Lambda all the elements are now 1 when only the diagnol elements should be 1 (the rest some fractional amount)??
I am at a complete loss. I thought about doing something like For i = 1 to n etc. but then it just looks like coding, which defeats the purpose of trying to make a calculation sheet documenting the procedure...
Any help and/or insights into what I am doing wrong here would be most welcomed :)
P.S. I've just noticed that there is an upload option :/ Wilson_Equation.mw.
