Question: error with data file attachment and loockup table
I have a problem with a 1D loockup table with a Data set file. It seems that there are some problems with the file but I don't understand which.
I tried to use a .xlsx file and the result is this error (note that the table in excel has 17 rows, so at the 18 there is nothing):
Then I tried with a .csv file and I had this error:
I put below the MapleSim file, is not completed: just to have a look at the errors and the attached file, so don't consider other things.
srpingdamper.msim
the .xlsx attached files is the following, while i'm not able to upload the .csv but it's the same one just saved as .csv:
damperTR.xlsx
Thanks a lot.
