Question: Difficult integer factorisation problem
Dear Maple users,
My problem is as follows:
I have a factor base [2,3,5,7,11,33,34,35,36,37,38,39,40]
The numbers from 2 till 11 are primes, the rest is not.
Then I have to factor (H+c1)(H+c2) in numbers of the factor base , where c1 and c2 go from 1 to some pre-defined limit. H=32 in my case.
And then I have to put the powers of the numbers of the factor base in a matrix. For example: (H+1)(H+1)=33² but also (H+1)(H+1)=3²*11².
That will become in matrix form [0 , 2, 0, 0, 2, 0, 0, 0, 0, 0, 0, 0, 0 ] but also (!) [0 , 0, 0, 0, 0, 2, 0, 0, 0, 0, 0, 0, 0 ].
This is not what I want! I want no double representations....
What I want is that (H+c1)(H+c2) should be represented in primes in the matrix if possible and else just represented as the other numbers.
hope you guys can help me!
