Question: Speeding Up Solving Equation Numerically
I am currently running into an issue where the numerical solution to an equation (involving an integral, yes, but the value I am solving for is simly a constant in the integral) is taking significantly longer than I would hope it would to solve. I am solving a similar equation (with a simpler expression) and it is significantly easier to solve, and I am hoping for that kind of speed.
On the last two lines in the attachment, I have two expressions. The penultimate expression is the baseline speed that I would like to match. The last expression is the fsolve I would like to speed up.
Is there any way to numerically speed up the process? I found that when I did tracelast after halting the process, there were HUGE numbers being added and subtracted, multiplied and divided. Not only did this significantly slow down the proecss but it also adds much numerical instability, which I would also like to avoid.
All help would be appreciated.
pole-dragging-mapleprimes.mw
