Question: Get values from numerical solving
Hi there,
I'm trying to get the values from the output of a dsolve command.
I have a system of differential equations:
de1 := diff(V(t), t) = V(t)-(1/3)*V(t)^3-W(t)+Ie;
de2 := diff(W(t), t) = 0.8e-1*(V(t)+.7-.8*W(t))
For a range of the independent variable t and for some given values of the parameter Ie, I would like to get the value of the dependent variable V, as well as its minimum/maximum values for each Ie.
Can anybody suggest a solution please?
This is the worksheet: MaplePrimes_dsolve_min-max.mw
Thanks,
jon
