Question: Difficulty with using Explore and plot with parameter
I'm trying to create interactive plots by using Explore to help demonstrate the effects parameters have on functions. I created one successfully to illustrate shifts and stretches of a polynomial:
transform(A,B,X,H,P,K):=Explore(plot(a*(b*x+h)^(p)+k,x=X),parameters=[a=A, b= B,h=H,p=P,k=K],placement=right)
However when I try to do the same with a solved ODE it returns an error message:
Explore(plot(1/(-p*x+x+1)^(1/(p-1)), x = -5 .. 5), parameters = [p = -20 .. 20], placement = right);
Executing this gives the error message:
Warning, expecting only range variable x in expression 1/((-p*x+x+1)^(1/(p-1))) to be plotted but found name p
INTERFACE_PLOT(AXESLABELS(x, ""),
VIEW(-5. .. 5., DEFAULT, _ATTRIBUTE("source" = "mathdefault"))),
I'm not sure why it is having difficulty dealing with "p" when it had no difficulty with the first. Any help would be appreciated!
