Question: External calling FORTRAN dll: Error loading external library
I've created compiled and executed Fortran 77 code, and then created a .dll file - using g77, for calling as external function in MAPLE 18. I have received the following : Error loading external library. Details are below. Can anyone explain what is going wrong?
Below is the history the steps I have taken:
Here is the contenct of my FORTAN source code file: test2.for
PROGRAM MAIN
REAL x,y, mult
x = 4.0
y = 3.0
OUT = mult(y,x)
WRITE(UNIT=*,FMT=11) OUT,x,y
11 FORMAT(1X,3E12.4)
END
function mult( a, b )
REAL a,b, mult
mult = a*b
END
The compile, execute and shared library creation steps are as follows  (using g77):
g77 -v -Wall -c -malign-double test2.for
g77 -v "test2.for" -o "test2"
..execution ran successfully. Creation of dll:
g77 -s -o "test2.dll" "test2.for"
...this executed successfully
Defining as external function in MAPLE:
fmult := define_external('mult', LIB = "S:/MRBwork/IT/Fortran/projects/MAPLE - Fortran/CERN primes/test2.dll", FORTRAN, 'a'::(float[4]), 'b'::(float[4]), RETURN::(float[4]))
... but received following error.
Error, external linking: error loading external library S:/MRBwork/IT/Fortran/projects/MAPLE - Fortran/CERN primes/test2.dll: @�b%
Can someone take and look at the above and explain what may be causing the erroo ion the loading the .dll file?
Melvin
