Question: on the frequent change of determinant in each run
Recently a a simple problem which i can not handle by myself, made me confused.
I have simple code of maple which is not stable at all. Everytime I run the code, the final result which is the determinant of a matrix, changes and I can not see the problem with the code. In fact i noticed that problem occures when the matrix is being build by culculating the coefficients of some constant values.  I have attached the code. Could you see what is wrong here?
Thanks by the way.
Download Code.mw
