Question: limit on elements of a Record
Following situation: I have Records with several members. These members in turn have varied expressions assigned to them: some have numbers, one has a Matrix, some have formulae. Example:
q:=Record(l=len,k1=kl/len,R=(a 6x6 Matrix dependent on len and kl/len));
I want to be able to use the limit command on each of the members of q such that each member gets assigned the correct limit of its expression. I.e. I want to write a function limit2 such that
limit2(q,len=0);
yields
Record(l=0,k1=infinity,R=(limit~(the Matrix,len=0))
The trick here is that the members of the Record vary for different Records but I want to write a function limit2 that works for all of these. I can make a list of the members by using exports(q) like this:
exlist:=[exports(q)];
and after some fiddling I found that I can run limit on each member in turn:
for nam in exlist do
  limit~(eval(parse(cat(elm,":-",eval(nam)))),len=0)
end do;
What I have not been able to do is putting the result back into the member of the Record. Usually I would use assign for such a task, but I am unable to get the correct name on the left side that lets me assign to it. These names would of course be q:-l, q:-k1 and q:-R in the above example. I tried the parse(cat(...)) construct above and variations, but in the best case the assignment does not happen, in worse cases I get an error thrown. Never do I get the actual assignment.
Any hint how to do this?
TIA,
M.D.
PS: FWIW, I am doing this on Mape 15.
