Question: Pasting list of points into worksheet creates 20 prompts. How do I stop this?
I want to paste a list of points generated by another program into a maple worksheet.
However, when I paste the list of points into the Maple worksheet, I get a command prompt after each defined point in the list.  Whereby, the executable code will not run.
I need a way to paste the list of points into the worksheet without any command prompts.  Is there a special entry mode?
Here's the list of points I want to paste into the worksheet:
[20,0,0],
[20,4,0],
[19,8,0],
[17,11,0],
[14,14,0],
[11,17,0]
Below is the worksheet code that I want to paste the list of points.
However, when I paste the list of points within the "pointPlot3D" function -- I get a command prompt after each defined point in the list of points.  (So 30 points gives 30 command prompts.)  Whereby, when this code is executed, there is an error.    What I need is a means to paste this list of points into the worksheet WITHOUT the command prompts showing up.
> with(geom3d):
> with(plots):
> sphere1:=(x,y,z,R)->[x+R*cos(phi)*cos(theta),y+R*cos(phi)*sin(theta),z+R*sin(phi)]:
> Explore(display(
       plot3d(sphere1(0,0,0,Rp),phi=-Pi/2..Pi/2,theta=0..2*Pi),
               scaling = constrained, axes = boxed, style=wireframe, labels=[x,y,z],
       pointplot3d(
> [20,0,0],
> [20,4,0],
> [19,8,0],
> [17,11,0],
> [14,14,0],
> [11,17,0]
               symbol=circle,symbolsize=10)  ),
       parameters=[Rp=3..20],         initialvalues=[Rp=20] );
