Question: Trapping the stop button
This Question involves using dsolve(..., numeric) for an IVP specifed by a procedure. This is based on a Question asked earlier today. In this Question, I have no interest in how to solve this IVP or in why this solution technique fails. In the worksheet below, the odeplot command seems to get stuck in an infinite loop (I am not interested in why that happens), and I press the stop button (in the Standard GUI). Then, instead of the usual Warning, computation interupted message followed by a return to the command prompt, I get an informative message and the plot that has been computed so far. This seems like a very useful feature: to return the results computed so far after an interuption. Furthermore, those results are programmatically accessible. My Question is How is this done? How do you trap the stop button and return the results?
Sys:= proc(N,t,Y,YP)
local eqs,yp2,yp4;
     YP[1]:= Y[2];
     YP[3]:= Y[4];
     eqs:= [
          yp2*Y[3]+yp4*Y[2]*sin(Y[1]^2)+cos(yp4*Y[3]) = sin(t),
          Y[2]*yp4*sin(Y[1]*Y[3])+5*yp2*Y[4]*cos(Y[1]^2)+t^2*Y[1]*Y[3]^2 = exp(-Y[3]^2)
     YP[2],YP[4]:= op(subs(fsolve(eqs,{yp2=1,yp4=2}),[yp2,yp4]))
res:= dsolve(
     numeric, procedure= Sys, initial= Array([1,1,2,2]),
     number= 4, procvars= [x1(t),diff(x1(t),t),x2(t),diff(x2(t),t)],
     start= 0, maxfun= 0
plots:-odeplot(res, [t,x1(t)], 0..0.27);
#After 10 seconds or so, (I did)/(you should) hit the stop button.
Warning, cannot evaluate the solution further right of .25109286, cannot downgrade delay storage for problems with delay derivative order > 1, try increasing delaypts
#Note that the command's result is still programmatically accessible:
P:= %;
PLOT(CURVES(Array(1..201, 1..2, {(1, 1) = .0, (1, 2) = 1.0, (2, 1) = 0.135e-2, (2, 2) = 1.001349729199153, (3, 1) = 0.27e-2, (3, 2) = 1.0026989169868508, (4, 1) = 0.405e-2, (4, 2) = 1.004047563645964, (5, 1) = 0.54e-2, (5, 2) = 1.005395669456049, (6, 1) = 0.675e-2, (6, 2) = 1.0067432346933451, (7, 1) = 0.81e-2, (7, 2) = 1.0080902596307788, (8, 1) = 0.945e-2, (8, 2) = 1.0094367445379593, (9, 1) = 0.108e-1, (9, 2) = 1.0107826896811836, (10, 1) = 0.1215e-1, (10, 2) = 1.01212809532343, (11, 1) = 0.135e-1, (11, 2) = 1.0134729617243639, (12, 1) = 0.1485e-1, (12, 2) = 1.0148172891403349, (13, 1) = 0.162e-1, (13, 2) = 1.0161610778243784, (14, 1) = 0.1755e-1, (14, 2) = 1.0175043280262126, (15, 1) = 0.189e-1, (15, 2) = 1.0188470399922427, (16, 1) = 0.2025e-1, (16, 2) = 1.020189213965557, (17, 1) = 0.216e-1, (17, 2) = 1.0215308501859302, (18, 1) = 0.2295e-1, (18, 2) = 1.0228719488898206, (19, 1) = 0.243e-1, (19, 2) = 1.0242125103103719, (20, 1) = 0.2565e-1, (20, 2) = 1.0255525346774133, (21, 1) = 0.27e-1, (21, 2) = 1.0268920222174571, (22, 1) = 0.2835e-1, (22, 2) = 1.0282309731537027, (23, 1) = 0.297e-1, (23, 2) = 1.0295693877060321, (24, 1) = 0.3105e-1, (24, 2) = 1.0309072660910137, (25, 1) = 0.324e-1, (25, 2) = 1.0322446085219004, (26, 1) = 0.3375e-1, (26, 2) = 1.0335814152086296, (27, 1) = 0.351e-1, (27, 2) = 1.0349176863578238, (28, 1) = 0.3645e-1, (28, 2) = 1.0362534221727904, (29, 1) = 0.378e-1, (29, 2) = 1.037588622853522, (30, 1) = 0.3915e-1, (30, 2) = 1.0389232885966946, (31, 1) = 0.405e-1, (31, 2) = 1.0402574195956709, (32, 1) = 0.4185e-1, (32, 2) = 1.041591016040497, (33, 1) = 0.432e-1, (33, 2) = 1.0429240781179057, (34, 1) = 0.4455e-1, (34, 2) = 1.044256606011312, (35, 1) = 0.459e-1, (35, 2) = 1.0455885999008183, (36, 1) = 0.4725e-1, (36, 2) = 1.04692005996321, (37, 1) = 0.486e-1, (37, 2) = 1.0482509863719582, (38, 1) = 0.4995e-1, (38, 2) = 1.0495813792972193, (39, 1) = 0.513e-1, (39, 2) = 1.0509112389058335, (40, 1) = 0.5265e-1, (40, 2) = 1.0522405653613263, (41, 1) = 0.54e-1, (41, 2) = 1.0535693587831985, (42, 1) = 0.5535e-1, (42, 2) = 1.0548976192244952, (43, 1) = 0.567e-1, (43, 2) = 1.0562253468268996, (44, 1) = 0.5805e-1, (44, 2) = 1.0575525417260814, (45, 1) = 0.594e-1, (45, 2) = 1.058879204046671, (46, 1) = 0.6075e-1, (46, 2) = 1.0602053339022601, (47, 1) = 0.621e-1, (47, 2) = 1.0615309313954047, (48, 1) = 0.6345e-1, (48, 2) = 1.0628559966176196, (49, 1) = 0.648e-1, (49, 2) = 1.0641805296493847, (50, 1) = 0.6615e-1, (50, 2) = 1.0655045305601394, (51, 1) = 0.675e-1, (51, 2) = 1.0668279994082868, (52, 1) = 0.6885e-1, (52, 2) = 1.06815093624119, (53, 1) = 0.702e-1, (53, 2) = 1.0694733410951756, (54, 1) = 0.7155e-1, (54, 2) = 1.0707952139955317, (55, 1) = 0.729e-1, (55, 2) = 1.0721165549565084, (56, 1) = 0.7425e-1, (56, 2) = 1.0734373639813168, (57, 1) = 0.756e-1, (57, 2) = 1.074757641062132, (58, 1) = 0.7695e-1, (58, 2) = 1.0760773861800887, (59, 1) = 0.783e-1, (59, 2) = 1.0773965993052852, (60, 1) = 0.7965e-1, (60, 2) = 1.078715280396781, (61, 1) = 0.81e-1, (61, 2) = 1.0800334294025973, (62, 1) = 0.8235e-1, (62, 2) = 1.081351046259718, (63, 1) = 0.837e-1, (63, 2) = 1.082668130894088, (64, 1) = 0.8505e-1, (64, 2) = 1.0839846832206155, (65, 1) = 0.864e-1, (65, 2) = 1.0853007031431687, (66, 1) = 0.8775e-1, (66, 2) = 1.08661619055458, (67, 1) = 0.891e-1, (67, 2) = 1.0879311453366416, (68, 1) = 0.9045e-1, (68, 2) = 1.0892455673601087, (69, 1) = 0.918e-1, (69, 2) = 1.0905594564846983, (70, 1) = 0.9315e-1, (70, 2) = 1.0918728125590897, (71, 1) = 0.945e-1, (71, 2) = 1.0931856354209235, (72, 1) = 0.9585e-1, (72, 2) = 1.0944979248968028, (73, 1) = 0.972e-1, (73, 2) = 1.0958096808022917, (74, 1) = 0.9855e-1, (74, 2) = 1.097120902941917, (75, 1) = 0.999e-1, (75, 2) = 1.098431591109168, (76, 1) = .10125, (76, 2) = 1.0997417450864941, (77, 1) = .1026, (77, 2) = 1.1010513646453082, (78, 1) = .10395, (78, 2) = 1.1023604495459853, (79, 1) = .1053, (79, 2) = 1.1036689995378606, (80, 1) = .10665, (80, 2) = 1.1049770143592332, (81, 1) = .108, (81, 2) = 1.1062844937176912, (82, 1) = .10935, (82, 2) = 1.1075914369810387, (83, 1) = .1107, (83, 2) = 1.108897843678326, (84, 1) = .11205, (84, 2) = 1.1102037134210607, (85, 1) = .1134, (85, 2) = 1.1115090457860155, (86, 1) = .11475, (86, 2) = 1.1128138403152263, (87, 1) = .1161, (87, 2) = 1.1141180965159976, (88, 1) = .11745, (88, 2) = 1.1154218138608973, (89, 1) = .1188, (89, 2) = 1.1167249917877577, (90, 1) = .12015, (90, 2) = 1.118027629699678, (91, 1) = .1215, (91, 2) = 1.1193297269650222, (92, 1) = .12285, (92, 2) = 1.1206312829174188, (93, 1) = .1242, (93, 2) = 1.1219322968557623, (94, 1) = .12555, (94, 2) = 1.123232768044212, (95, 1) = .1269, (95, 2) = 1.1245326957121933, (96, 1) = .12825, (96, 2) = 1.1258320790543948, (97, 1) = .1296, (97, 2) = 1.1271309172307735, (98, 1) = .13095, (98, 2) = 1.1284292093665487, (99, 1) = .1323, (99, 2) = 1.1297269545522062, (100, 1) = .13365, (100, 2) = 1.131024151843497, (101, 1) = .135, (101, 2) = 1.1323208002614376, (102, 1) = .13635, (102, 2) = 1.133616898792309, (103, 1) = .1377, (103, 2) = 1.1349124463876585, (104, 1) = .13905, (104, 2) = 1.1362074419642976, (105, 1) = .1404, (105, 2) = 1.137501884404303, (106, 1) = .14175, (106, 2) = 1.1387957725550182, (107, 1) = .1431, (107, 2) = 1.1400891052290492, (108, 1) = .14445, (108, 2) = 1.1413818812042709, (109, 1) = .1458, (109, 2) = 1.1426740992238196, (110, 1) = .14715, (110, 2) = 1.1439657579960996, (111, 1) = .1485, (111, 2) = 1.1452568561947796, (112, 1) = .14985, (112, 2) = 1.1465473922561644, (113, 1) = .1512, (113, 2) = 1.1478373642224777, (114, 1) = .15255, (114, 2) = 1.14912677047606, (115, 1) = .1539, (115, 2) = 1.1504156093257876, (116, 1) = .15525, (116, 2) = 1.1517038789853584, (117, 1) = .1566, (117, 2) = 1.1529915775732906, (118, 1) = .15795, (118, 2) = 1.1542787031129238, (119, 1) = .1593, (119, 2) = 1.1555652535324183, (120, 1) = .16065, (120, 2) = 1.1568512266647548, (121, 1) = .162, (121, 2) = 1.1581366202477354, (122, 1) = .16335, (122, 2) = 1.1594214319239837, (123, 1) = .1647, (123, 2) = 1.1607056592409424, (124, 1) = .16605, (124, 2) = 1.1619892996508772, (125, 1) = .1674, (125, 2) = 1.1632723505108726, (126, 1) = .16875, (126, 2) = 1.1645548090828357, (127, 1) = .1701, (127, 2) = 1.165836672533493, (128, 1) = .17145, (128, 2) = 1.1671179379343934, (129, 1) = .1728, (129, 2) = 1.1683986022619053, (130, 1) = .17415, (130, 2) = 1.169678662397219, (131, 1) = .1755, (131, 2) = 1.1709581151263448, (132, 1) = .17685, (132, 2) = 1.172236957140115, (133, 1) = .1782, (133, 2) = 1.1735151850341814, (134, 1) = .17955, (134, 2) = 1.174792795282732, (135, 1) = .1809, (135, 2) = 1.1760697835893776, (136, 1) = .18225, (136, 2) = 1.1773461457270373, (137, 1) = .1836, (137, 2) = 1.1786218774884782, (138, 1) = .18495, (138, 2) = 1.179896974422449, (139, 1) = .1863, (139, 2) = 1.181171431833682, (140, 1) = .18765, (140, 2) = 1.182445244782893, (141, 1) = .189, (141, 2) = 1.1837184080867809, (142, 1) = .19035, (142, 2) = 1.1849909163180268, (143, 1) = .1917, (143, 2) = 1.1862627638052967, (144, 1) = .19305, (144, 2) = 1.1875339446332376, (145, 1) = .1944, (145, 2) = 1.1888044526424812, (146, 1) = .19575, (146, 2) = 1.1900742814296414, (147, 1) = .1971, (147, 2) = 1.1913434243473158, (148, 1) = .19845, (148, 2) = 1.1926118745040841, (149, 1) = .1998, (149, 2) = 1.193879624764512, (150, 1) = .20115, (150, 2) = 1.195146667749144, (151, 1) = .2025, (151, 2) = 1.1964129956664247, (152, 1) = .20385, (152, 2) = 1.1976785994686407, (153, 1) = .2052, (153, 2) = 1.1989434702227826, (154, 1) = .20655, (154, 2) = 1.2002075985381981, (155, 1) = .2079, (155, 2) = 1.2014709744148189, (156, 1) = .20925, (156, 2) = 1.2027335872431564, (157, 1) = .2106, (157, 2) = 1.2039954258043046, (158, 1) = .21195, (158, 2) = 1.2052564782699382, (159, 1) = .2133, (159, 2) = 1.2065167322023145, (160, 1) = .21465, (160, 2) = 1.2077761745542712, (161, 1) = .216, (161, 2) = 1.2090347916692288, (162, 1) = .21735, (162, 2) = 1.2102925692811892, (163, 1) = .2187, (163, 2) = 1.2115494925044938, (164, 1) = .22005, (164, 2) = 1.2128055446540236, (165, 1) = .2214, (165, 2) = 1.2140607079057624, (166, 1) = .22275, (166, 2) = 1.2153149635677838, (167, 1) = .2241, (167, 2) = 1.216568291442756, (168, 1) = .22545, (168, 2) = 1.2178206698279472, (169, 1) = .2268, (169, 2) = 1.2190720755152231, (170, 1) = .22815, (170, 2) = 1.2203224837910482, (171, 1) = .2295, (171, 2) = 1.221571868436484, (172, 1) = .23085, (172, 2) = 1.22282020172719, (173, 1) = .2322, (173, 2) = 1.224067453329788, (174, 1) = .23355, (174, 2) = 1.225313589366023, (175, 1) = .2349, (175, 2) = 1.226558573530251, (176, 1) = .23625, (176, 2) = 1.227802365810496, (177, 1) = .2376, (177, 2) = 1.229044922475539, (178, 1) = .23895, (178, 2) = 1.2302861960749185, (179, 1) = .2403, (179, 2) = 1.2315261354389295, (180, 1) = .24165, (180, 2) = 1.2327646837576534, (181, 1) = .243, (181, 2) = 1.2340017760538164, (182, 1) = .24435, (182, 2) = 1.2352373405616506, (183, 1) = .2457, (183, 2) = 1.2364712973589982, (184, 1) = .24705, (184, 2) = 1.2377035562942194, (185, 1) = .2484, (185, 2) = 1.2389340149185948, (186, 1) = .24975, (186, 2) = 1.2401625575137232, (187, 1) = .2511, (187, 2) = undefined, (188, 1) = .25245, (188, 2) = undefined, (189, 1) = .2538, (189, 2) = undefined, (190, 1) = .25515, (190, 2) = undefined, (191, 1) = .2565, (191, 2) = undefined, (192, 1) = .25785, (192, 2) = undefined, (193, 1) = .2592, (193, 2) = undefined, (194, 1) = .26055, (194, 2) = undefined, (195, 1) = .2619, (195, 2) = undefined, (196, 1) = .26325, (196, 2) = undefined, (197, 1) = .2646, (197, 2) = undefined, (198, 1) = .26595, (198, 2) = undefined, (199, 1) = .2673, (199, 2) = undefined, (200, 1) = .26865, (200, 2) = undefined, (201, 1) = .27, (201, 2) = undefined}, datatype = float[8], order = C_order), COLOUR(RGB, .47058824, 0., 0.54901961e-1)), AXESLABELS(t, x1))
Download trap_stop_button.mw
