Question: How to label contours in Maple 17?
hi friends
i have a question and i could find the answer in existing questions but it was not clear at all!!!
i want to label my contours and i know that i should use lebelledcontourplot command.
But how?!
i could find an answer:
"1- First download the files located on his webpage.  Advisor6.zip    It should be zipped with 3 files in it.
2 - Unzip them and copy them into a directory which you name, probably somewhere in the maple directory named advisor.  c:\maple12\advisor
3 - Then create a maple.ini in the maple12 directory with the following line to match your directory location
libname:= `c:/maple12/advisor`, libname:  just like on the instruction installation page."
these are my questions:
1-how can i create a maple.ini?!
2-what should i do with the file i will create?
please explain more about the third phrase and explain exactly what should i do step by step.
thanks a lot
