Question: Remove Assumptions
I am having trouble removing assumptions that are stored within expresssions.
Example code:
assume(l1>0): # this assumptions later helps to find a solution for a geometric problem with two four-bar-linkages
a := sqrt(l1);
save a, "test.m";
read "test.m"
a; # the assumptions are stored within the saved data
l1:='l1'; # try to remove the assumption
a; # assumption in a still existing
subs({l1=2}, a); # nothing happens: I can not access l1 any more
subs({l1~=2}, a); # This does not work either, nothing changes in a
So my question is: How do I remove the assumption within a stored expression?
My main problem lies in the handling of the expression with assumptions. At some point, I want to generate Matlab code, and the codegen-command gives me:
Warning, the following variable name replacements were made: l1~ -> cg
