Question: Matrix Procedure Query
Hi. I'm hacing trouble writing a maple procedure for the question below, can anyone help?
Write a maple procedure which takes as its input the vectoeat u1 and u2 and the eigenvectors lambda1 and lambda2 where u1,u2 are element of R^2 and the lambdas are real numbers.
If u1,U2 is linearly independent then the output is the matrix A an element of R^2x2 with the property that Au1= lambda1u1 and AU2=lambda2u2;
if u1,u2 is linearly dependent then the output is the statement "not an eigenbasis".
I I then have two inputs which I have to do but I'm not sure on how to write the procedure. Any help will be much appreciated.
