Question: Question about CodeGeneration
using the code generator assistant I entered the following function
p := proc (z::(float[8]))
local a::integer, accm::(float[8]), k::integer, k1::(float[8]), c;
c := Array([0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0], order = C_order, datatype = float[8]);
k1 := 1;
c[1] := evalf(sqrt(2*Pi));
a := 12;
for k to a-1 do c[k+1] := evalf(exp(a-k)*(a-k)^(k-1/2)/k1); k1 := -k1*k end do;
accm := c[1];
for k to a-1 do accm := accm+evalf(c[k+1]/(z+k)) end do;
accm := accm*evalf(exp(-z-a)*(z+a)^(z+1/2));
return accm/z
end proc
the code-generated julia code follows
function input(z)
c = [0,0,0,0,0,0,0,0,0,0,0,0]
k1 = 1
c[0] = (sqrt(2 * pi))
a = 12
for k = 1:a - 1
c[k] = (exp(a - k) * (a - k) ^ (k - 1//2) / k1)
k1 = -k1 * k
accm = c[0]
for k = 1:a - 1
accm = accm + (c[k] / (z + k))
accm = accm * (exp(-z - a) * (z + a) ^ (z + 1//2))
return(accm / z)
end
two things are wrong
1: no end after loop end
2: array index starts at 0, it should be 1 and of course the array references should reflect that
btw, it would be nice to be able to enter code tags like [code] code here [/code]
