Question: How do I fill an Array?
I'm trying to fill an Array but I don't know the correct syntax, and Maple help isn't much use.
How do I form an Array, A, which has 10 rows and 2 columns. Where one column is say the row number squared and the other column is the row number cubed.
So A would be:
[1 1]
[4 8]
[9 27] .....
Also, I'm using the square and cube numbers as an example. But is there a general format for doing this, whatever the values I want to put in the array are?
