Question: Kummer Function
Hi all,
It is believeble for me that the KummerU function is infinite or has a singular solution at r=0;
but without the command D(R) and dsolve ({er, D(R)(0)=0}, {R(r)}) that show the r=0 is a singular solution for the R(r), how could I prove it without using of these commands: for example is plotting of this function applicable??
while we have not the value of the  \lambda
eq := diff(R(r), r, r)+(diff(R(r), r))/r+(-r^2+1)*lambda^2*R(r) = 0;
diff(diff(R(r), r), r)+(diff(R(r), r))/r+(-r^2+1)*lambda^2*R(r) = 0
dsolve(eq);
R(r) = _C1*exp(-(1/2)*lambda*r^2)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+_C2*exp(-(1/2)*lambda*r^2)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2)
dsolve({eq, (D(R))(0) = 0}, {R(r)})
R := proc (r) options operator, arrow; C1*exp(-(1/2)*lambda*r^2)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+_C2*exp(-(1/2)*lambda*r^2)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2) end proc
D(R)
proc (r) options operator, arrow; -C1*lambda*r*exp(-(1/2)*lambda*r^2)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+2*C1*exp(-(1/2)*lambda*r^2)*((lambda*r^2-1/2-(1/4)*lambda)*KummerM(1/2-(1/4)*lambda, 1, lambda*r^2)+(1/2+(1/4)*lambda)*KummerM(-1/2-(1/4)*lambda, 1, lambda*r^2))/r-_C2*lambda*r*exp(-(1/2)*lambda*r^2)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2)+2*_C2*exp(-(1/2)*lambda*r^2)*((lambda*r^2-1/2-(1/4)*lambda)*KummerU(1/2-(1/4)*lambda, 1, lambda*r^2)-KummerU(-1/2-(1/4)*lambda, 1, lambda*r^2))/r end proc
Download Kummer.mwKummer.mw
