Question: Overlapping subsections in worksheet
The problem that I'm asking about here doesn't show in the MaplePrimes display of the worksheet below; you'll need to download the worksheet to see it. The problem is that the last subsection (which is currently empty) overlaps with the second-to-last subsection. It also overlapped when it was not empty. I just want to delete that last subsection, but nothing that I've tried works. This is not the first time that I've had overlapping subsections, but previously I've always been able to fix the problem by closing and re-opening the worksheet. That doesn't work in this case.
ReparamT.mw: A scratch space for testing NewSLO:-reparam
Modify at will.
Created by Carl 2016Jun17.
Important: If any change is made to KB.mpl or NewSLO.mpl then before running this worksheet
1. Restart all open Maple sessions.
2. From the command line, run "cmaple -q < update-archive.mpl".
dir:= "C:/cygwin64/home/owner/hakaru/maple/":
Load:= proc(package::symbol) read ""||dir||package||".mpl" end proc:
with(NewSLO);
with(KB);
Load(ReparamT);
Passed cases
Cases being worked on
infolevel[reparam]:= 2:
Linear fractional transformation (LFT) with symbolic coefficients
LFT with explicit coefficients
Simplest nonlinear LFT: 1/x
Symbolic constant multiple
Two-variable LFT with Gamma
Two-variable constant multiple with ChiSquare and Standard Normal
(t16) Sum of std normals to Normal(0, sqrt(2))
(t20) Sum of n Bernoullis to Binomial
(t23) Sum of Exponentials to Gamma
Download ReparamT.mw
