Question: How to substitute values from multiple lists into a formula ?
Dear All
For six parameters, I have corresponding list of their values and there are eight values for every parameter. I need to put these values in a formula to obtain a list of output values. There are two formulas one for 'P' and next is for 'RL'. I have used value of 'P' to calculate value of 'RL'. There are some complex number too, for which I have used modulus and final value is calculated by using 'evalf', but this command is not returning proper values for list as required. But this command works fine when I use single value from every list to calculate RL.
The Maple sheet attached herewith.
List.mw
Regards
