Question: Is the loading of packages broken?
I am writing a package to define a few Records and collect some quantities and formulae to do some arithmetic with.
At some point I started running into a severe problem: Each time I want to use one of the exports form the module, the Maple kernel dies with a "Stack limit exceeded" message. The issue is: This seems to happen only on Maple 2016. I had some issues in Maple 2015 but that got sorted by rewriting some stuff. I never had any issue like that with Maple 15. I went as far as commenting out most of my .mapleinit code to make sure that did not cause issues. The code works as intended in Maple 15 and in Maple 2015.
I am posting this here and am asking others to see if they can reproduce this. Needless to say I will SCR this. But I actually need to get this to work.
The error can be triggered by simply entering
Booster;
after loading the package. Needless to say, it should just echo the name "Booster", to get more one would need to enter eval(Booster) (due to the last-name evaluation rules).
Thanks,
M.D.
BooMBA.mw
