Question: Possible to plot/draw triangles knowing only the sides and angles?
Hi, I was wondering, as stated in the title, if it is possible to plot/draw a triangle knowing only the sides and angles, and not the coordinates for each point making up its corners. If not, what would be the easiest way, to calculate the coordinates using the sides and angles (assuming I know the value for each side and corner) and then plot/draw it?
I'm rather green when it comes to using Maple, so if you could explain it in a simple way that would be appreciated.
