Question: Convert Peano curve into a function
Hi!
I have seen th following procedure to compute the image of the points of [0,1] under the so called Peano space-filling curve (sorry, I have to pasted the code in "text plane" mode):
P[0] := (x, y) -> ((1/3)*y, (1/3)*x);
P[1] := (x, y) -> (-(1/3)*x+1/3, (1/3)*y+1/3);
P[2] := (x, y) -> ((1/3)*x, (1/3)*y+2/3);
P[3] := (x, y) -> ((1/3)*x+1/3, -(1/3)*y+1);
P[4] := (x, y) -> (2/3-(1/3)*y, 2/3-(1/3)*x);
P[5] := (x, y) -> ( (1/3)*x+1/3, 1/3-(1/3)*y));
 P[6] := (x, y) -> (1/3)*x+2/3, (1/3)*y);
P[7] := (x, y) -> (-(1/3)*x+1, (1/3)*y+1/3);
P[8] := (x, y) -> ((1/3)*x+2/3, (1/3)*y+2/3);
peano := proc (t::numeric, depth::integer)
local q, r; global P;
if depth = 0 then return 0, 0 end if;
q := floor(9*t); r := 9*t-q;
return P[q](peano(r, depth-1))
end proc;
Now, I need to use the procedure "peanofun" as a function. For instance, if we define f:=(x,y)->x+y, I need to use (plot, compute, etc) for instance, the function f(peanofun(t,5))
Can you help me with this issue, please?
Many thanks for your time!
