Question: why simplify command doesn't work for Ei function?
if I use the command below, I will get the right answer.
`assuming`([simplify((2*I)*deltas*Pi*BW*Ei(1, (2*I)*deltas*Pi*BW)-(2*I)*deltas*Pi*BW*Ei(1, -(2*I)*deltas*Pi*BW))], [real, BW > 0, deltas > 0, ts > 0, deltas <= ts, 2*BW*ts >= 1])
and the answer is :
2*BW*Pi*deltas*(Pi-2*Si(2*BW*Pi*deltas))
while I use the same command for the compliacated Ei function, it doesn't work any more, I don't know the reason.
 `assuming`([simplify(Ei(1, I*BW*Pi*deltas-(5*I)*BW*Pi*ts)-Ei(1, -I*BW*Pi*deltas+(5*I)*BW*Pi*ts), Ei)], [real, BW > 0, deltas > 0, ts > 0, deltas <= ts, 2*BW*ts >= 1])
 and it's reault is :
Ei(1,I*BW*Pi*deltas-5*I*BW*Pi*ts)-Ei(1,-I*BW*Pi*deltas+5*I*BW*Pi*ts)
