Question: How Do I Display Fast Parametric Surface with Smooth Hole?
Dear MaplePrimes team,
For display a beautiful parametric surface with hole (or pierced surface), unfortunately unlike CAD (computer-aided design) tool, Maple requires a large grid number. Therefore the computing is too long and requires huge RAM only with grid of [500,500] on a modern computer.
Fig. 1: For a complex surface such an aircraft fuselage here, Needs high grid, therefore, the compilation is too long with modern computer (Intel Core i7, 2.4 GHz CPU, 16 GB RAM). If displays supplementary windows holes on fuselage, the software may bug when the RAM is full.
Question 1:
In matter of low cost computation, do you have better solution to create a fast surface with smooth hole from given a parametric surface equation S(x,y) and given any convex/concave-closed parametric curve C(t) that is projected on surface S(x,y)?
Fig. 2: These surfaces are been created in Maple 2016 from given initial parametric surface equation and curve projected on the surface. But requires huge grid, huge RAM, and long time to get smooth hole when free CAD tools are fast and low RAM.
Question 2:
Because I noted that the Maple’s view option renderers smooth edges of any surface. My question is: Is it possible to use the internal structure of display/view used by Maple to apply at free boundaries? I think it will be possible to create many class of view, for examples: cylindrical sector, spherical sector views or more rather to be limited with conventional cubic view. And thus, I think it will be possible to create own smooth hole or multiple-hole on surface and get smooth pierced surface.
I know that almost of technicians/engineers will recommend me to use a CAD tool to create surface with hole. But the objective here is to keep purely a mathematical mind and work with exact equations (analytic equations).
On a free CAD tool, even the complex holes are created very fast only with low RAM. Why not on Maple?
Best.
Guy.
