Question: Why does applying this rule inside a procedure not work?
I want to apply a rule to simplify an expression. The applyrule command works, when used directly in the worksheet. When I try to use the command within a procedure, Maple throws an error I cannot decipher:
Error, (in PatternMatching:-AlgStruct:-InsertPattern) first operand of `::' must be a name
Here is a full demonstration worksheet:
anexp:=abs(x)^2;
abs(x)^2
simplify(anexp);
abs(x)^2
rmabssq := proc(inexp)
description "removes the abs^2 construct in an expression":
local ruleabssqared1,ruleabssqared2,outexp:
    ruleabssqared1:= abs(''a''::algebraic)^2= ''a''^2:
    ruleabssqared2:= abs('expand'(-''a'')::algebraic)^2= ''a'':
    outexp:= applyrule([ruleabssqared1,ruleabssqared2],inexp):
    return outexp:
end proc;
proc (inexp) local ruleabssqared1, ruleabssqared2, outexp; description "removes the abs^2 construct in an expression"; ruleabssqared1 := abs(''a''::algebraic)^2 = ''a''^2; ruleabssqared2 := abs((('expand')(-''a''))::algebraic)^2 = ''a''; outexp := applyrule([ruleabssqared1, ruleabssqared2], inexp); return outexp end proc
## does not work :(
rmabssq(anexp);
## works!
newexp:= applyrule([ruleabssqared1,ruleabssqared2],anexp);
x^2
Download applyrule_4.mw
Thanks for your help
