Question: How to put square brackets around output
Hello
I'm importing some data from Excel which comes across as L:
L := Matrix(1, 6, [["TC,DB", "PC,JL", "TD,JK", "IW,CM", "CC,PG", "KJ,DJ"]])
M: = convert( L,'list' );
map(convert, M, 'name') ; # remove inverted commas
[`TC,DB`, `PC,JL`, `TD,JK`, `IW,CM`, `CC,PG`, `KJ,DJ`]
How to I add square brackets to each pair in the output?
What I want is a command to display L or M as:
[[TC,DB], [PC,JL], [TD,JK], [IW,CM], [CC,PG], [KJ,DJ]]
