Question: Using interface(typesetting = extended) command messed with the variable in the supercript form
I used the interface(typesetting = extended) command to change the notation used for time derivative of o variable.
But it doesn't seem to be working well when the variable is in the supercript form (check the last line).
How can I solve this issue?
Mapleprimesquestion.mw
