Question: fsolve interval resolution
When attempting to numerically solve for a function using fsolv it is possible that the function has multiple roots.  So to focus on a particular region you specify a range such as:
xmax := fsolve(S, x = 0 .. 1/2)
Is it possible fsolve may not resolve the solution due to the fact that delta x is not small enough or does fsolve autonomously adjust delta x in order to find the solution?  If not, how do you manually dictate the delta x for the interval specified?
