Question: support link is obsolete.
I am facing the same problem with Maple 17. Which is also discussed here
https://www.mapleprimes.com/questions/222168-Maple-Not-Evaluating-Symbolic-Variables?reply=reply
But the link provided below is dead
https://www.maplesoft.com/support/faqs/detail.aspx?sid=34802
Can you recall how to solve it?  I have tried your solution below, but it did not solve it.
"@peacess If the file isn't there you can just create a new file with a text editor (e.g. Notepad) and add the required option.
Or you can use the maplejava.l4j.ini file inside the .zip file I've attached:  maplejava.l4j.zip"
Thank you.
