Question: Error, invalid input: diff received tau/omega, which is not valid for its 2nd argument
hello
How I can remove these errors?
erorr.mw
restart; eq31g := diff(u(t), `$`(t, 2))+u(t)+mu[s]*(diff(u(t), t))^3 = (1-mu[s])*(diff(u(t), t))*(diff(u(t), `$`(t, 2)))
diff(diff(u(t), t), t)+u(t)+mu[s]*(diff(u(t), t))^3 = (1-mu[s])*(diff(u(t), t))*(diff(diff(u(t), t), t))
(1.1)
eq33a:=subs(t=tau/omega,value(subs(u(t)=u(omega*t),eq31g)));
diff(diff(u(tau), tau/omega), tau/omega)+u(tau)+mu[s]*(diff(u(tau), tau/omega))^3 = (1-mu[s])*(diff(u(tau), tau/omega))*(diff(diff(u(tau), tau/omega), tau/omega))
(2.1)
omgRule:=omega=1+add(epsilon^i*omega[i],i=1..2);
omega = epsilon^2*omega[2]+epsilon*omega[1]+1
(2.2)
uExpRule:=u(tau)=add(epsilon^i*u[i](tau),i=1..3);
u(tau) = epsilon*u[1](tau)+epsilon^2*u[2](tau)+epsilon^3*u[3](tau)
(2.3)
temp:=subs(uExpRule,omgRule,convert(eq33a,diff));
eq33b:=convert(series(lhs(temp),epsilon,4),polynom)=0;
Error, invalid input: lhs received temp, which is not valid for its 1st argument, expr
eqEps:=seq(coeff(lhs(eq33b),epsilon,i)=0,i=1..3);
Error, invalid input: lhs received eq33b, which is not valid for its 1st argument, expr
The general solution of the first-order equation, eqEps[1], can be expressed as
sol1:=dsolve({eqEps[1],u[1](0)=a,D(u[1])(0)=0},u[1](tau));
Error, (in dsolve) not a system with respect to the unknowns [u[1](tau)]
eq33c:=subs(u[1]=u[2],lhs(eqEps[1])=lhs(eqEps[1]))-subs(sol1,0=lhs(eqEps[2]));
Error, invalid input: lhs received eqEps[1], which is not valid for its 1st argument, expr
Expanding the right-hand side of eq33c in a Fourier series using trigonometric identities yields
eq33c_RHS:=combine(rhs(eq33c));
Error, invalid input: rhs received eq33c, which is not valid for its 1st argument, expr
Eliminating the terms,  and , demands that . Then, the particular solution of eq33c can be expressed as
sol2:=combine(subs(_C1=0,_C2=0,dsolve(subs(omega[1]=0,eq33c),u[2](tau))));
Error, (in dsolve) expecting an ODE or a set or list of ODEs. Received eq33c
Substituting sol1 and sol2 into the third-order equation, eqEps[3], and using the fact that , we obtain
eq33d:=subs(u[1]=u[3],lhs(eqEps[1])=lhs(eqEps[1]))-subs(sol1,sol2,omega[1]=0,0=lhs(eqEps[3]));
Expanding the right-hand side of eq33d in a Fourier series using trigonometric identities, we have
eq33d_RHS:=combine(rhs(eq33d));
Error, invalid input: rhs received eq33d, which is not valid for its 1st argument, expr
Eliminating the terms that lead to secular terms from eq33d_RHS demands that
omg2Rule:=omega[2]=solve(coeff(eq33d_RHS,cos(beta+tau)),omega[2]);
omega[2] = omega[2]
(2.4)
As discussed above, for a second-order uniform expansion, we do not need to solve for . Combining the first- and second-order solutions, we obtain, to the second approximation, that
combine(subs(sol1,sol2,uExpRule));
Error, invalid input: subs received sol1, which is not valid for its 1st argument
where
tau=subs(omega[1]=0,omg2Rule,subs(omgRule,omega*t));
tau = (epsilon^2*omega[2]+1)*t
(2.5)
Download erorr.mw
