Question: How to display more decimal numbers in maple
Why input fraction to eigenvector and then evalf output are all the same when input different ?
i would like to see more decimal numbers
digits := 36
command can not show more decimal numbers
why can not see the difference?
if start from fraction
After set round screen display to 36 digits in options
If start from floating value
the result different from start from fraction
start from which is the most accurate and correct?
if fraction is correct, why all result are the same even if input are different?
