Question: is assume(...); do_something(); the same as do_something() assuming(...); ?
Why is assume(...) do_something();  gives an error when I run the code one more time, but do_something() assuming ...; do not give an error when everything else is the same?
Is there semantic difference between the two forms? I thought they should work the same way. Here is an example
#in separate cell
#in separate cell
interface(showassumed=0):
pde := diff(u(x, t), t)=k*diff(u(x, t), x$2):
ic:=u(x,0)=0: bc:=u(0,t)=t:
assume(x>0);assume(t>0);assume(k>0):
sol:= pdsolve({pde,ic,bc},u(x,t)):
#in separate cell. Now this gives error
#error message now
Here is screen shot
Now will do the same, but use assuming. Now there is no error
#in one cell
#in one cell
sol:= pdsolve({pde,ic,bc},u(x,t)) assuming x>0,t>0,k>0:
#in one cell, no error
Here is screen shot
Why does one give an error, but the second one does not?
I thought they work the same way. Which method is recommended to use?
or
Maple 2018 on windows.
