Question: Random code "C " to -> Maple
Hello I trie this code C:
FUNCTION ran1(idum)
INTEGER idum,IA,IM,IQ,IR,NTAB,NDIV
REAL ran1,AM,EPS,RNMX
PARAMETER (IA=16807,IM=2147483647,AM=1./IM,IQ=127773,IR=2836,
* NTAB=32,NDIV=1+(IM-1)/NTAB,EPS=1.2e-7,RNMX=1.-EPS)
“Minimal” random number generator of Park and Miller with Bays-Durham shuffle and
added safeguards. Returns a uniform random deviate between 0.0 and 1.0 (exclusive of
the endpoint values). Call with idum a negative integer to initialize; thereafter, do not
alter idum between successive deviates in a sequence. RNMX should approximate the largest
floating value that is less than 1.
INTEGER j,k,iv(NTAB),iy
SAVE iv,iy
DATA iv /NTAB*0/, iy /0/
if (idum.le.0.or.iy.eq.0) then Initialize.
idum=max(-idum,1) Be sure to prevent idum = 0.
do 11 j=NTAB+8,1,-1 Load the shuffle table (after 8 warm-ups).
k=idum/IQ
idum=IA*(idum-k*IQ)-IR*k
if (idum.lt.0) idum=idum+IM
if (j.le.NTAB) iv(j)=idum
enddo 11
iy=iv(1)
endif
k=idum/IQ Start here when not initializing.
idum=IA*(idum-k*IQ)-IR*k Compute idum=mod(IA*idum,IM) without overflows by
if (idum.lt.0) idum=idum+IM Schrage’s method.
j=1+iy/NDIV Will be in the range 1:NTAB.
iy=iv(j) Output previously stored value and refill the shuffle taiv(
j)=idum ble.
ran1=min(AM*iy,RNMX) Because users don’t expect endpoint values.
return
END
How does this code in Maple?.
There are any sintaxis as *Value(point of addrees) that i  dont know this in Maple.
best Regars,
