Question: question on maplemint messages.
I am trying maplemint for first time, but some of the messages it generates do not seem to make sense to me and they all seem to be false alarms.
And not sure how make maplemint generate true warnings to make it easier to filter the real problems from the not real ones. For example, I made some module to try
my_module:=module()
export foo;
local  f,A,n,x;
#private stuff here
f:= x -> x^2:
A := int(f(x)*sin(n*x),x=0..Pi) assuming n::integer;
#public stuff here
foo:= proc()
        A;
end proc;
end module;
maplemint(my_module) generates
Module my_module()
  These local variables were never used:  x
  These local variables were used but never assigned a value:  n
  These local variables were assigned a value, but otherwise unused:  f
Well, "x" is clearly used. It is the integration variable?  And I can't assign value to "n", it is just a symbol used in the symbolic integration and assumed to be integer.
It also says "f" is not used. But "f" is used in definition of "A" inside the integrand.
So all these messages are not really needed. Is there a way to make maplemint not generate these? I do not see how I could change the code to remove these messages. Is something wrong with my code above?
Code works as expected
my_module:-foo();  gives (-Pi^2*(-1)^n*n^2+2*(-1)^n-2)/n^3
Here is another simpler example of where maplemint messages can't be removed no matter what.
foo:= proc()
	 local x;
	 plot(sin(x),x=-Pi..Pi);
end proc;
and maplemint(foo) gives
Procedure foo()
  These local variables were used but never assigned a value:  x
boo:= proc()
end proc;
And now
maplemint(boo);
Procedure boo()
  These names were used as global names but were not declared:  x
Here is another example where maplemint complains about option names for plot3 being undeclared
foo:= proc()
    local p,x,y;
    p:=plot3d(sin(x)*cos(y),x=0..Pi,y=0..Pi,
              axes = none, projection=0.9,
              orientation=[-30,55,0], scaling=unconstrained
    p:
And
maplemint(foo);
Procedure foo()
     axes, none, orientation, projection, scaling, unconstrained
       x, y
If one has to go each time through 100's of messages like these in order to find 1 or 2 real ones which indicate real problems, then using maplemint is not going to an effective way to find problems in code.
