Question: Why does the procedure not execute?
In attempting to store procedures in a table to create an extensible module, I used the following procedure to test whether a procedure could be queried from the table and executed.
proc() print("Metric is default") end proc;
The result was proc () print("Metric is default") end proc
I have checked the statement with mint in the code editor, but it reports no errors. I get the same result when I use an eval statement around the procedure.  I would be very interested in understanding what is wrong with the procedure as defined.
