Question: non-trial solution
how I can find an non-trial solution (non-zero) for differential equations?
y.mw
restart; Nb := 2; Nt := .5; f1 := Nb*(diff(sigma(y), y, y))+Nt*(diff(theta(y), y, y)) = 0; f2 := diff(theta(y), y, y)+Nb*(diff(sigma(y), y))*(diff(theta(y), y))+Nt*(diff(theta(y), y))^2 = 0; f3 := (D(sigma))(0) = 0; f4 := (D(theta))(0) = 0; f5 := sigma(1) = 0; f6 := theta(1) = 0; f7 := dsolve({f1, f2, f3, f4, f5, f6}, {sigma(y), theta(y)}, numeric, output = listprocedure); plots:-odeplot(f7, [[y, sigma(y)]], y = 0 .. 1, legend = [y], labels = [y, sigma(y)]); plots:-odeplot(f7, [[y, theta(y)]], y = 0 .. 1, legend = [y], labels = [y, theta(y)])
2
.5
2*(diff(diff(sigma(y), y), y))+.5*(diff(diff(theta(y), y), y)) = 0
diff(diff(theta(y), y), y)+2*(diff(sigma(y), y))*(diff(theta(y), y))+.5*(diff(theta(y), y))^2 = 0
(D(sigma))(0) = 0
(D(theta))(0) = 0
sigma(1) = 0
theta(1) = 0
[y = proc (y) local _res, _dat, _solnproc; option `Copyright (c) 1993 by the University of Waterloo. All rights reserved.`; _dat := Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); YP := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = -.0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = -.0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = -.0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = -.0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = -.0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = -.0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = -.0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = -.0}, datatype = float[8], order = C_order); errproc := proc (x_bvp) local outpoint, X, Y, yout, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; Digits := 15; outpoint := evalf(x_bvp); X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then error "this is already the error procedure" elif outpoint = "rawdata" then return [4, 8, [sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], X, Y] else return ('procname')(x_bvp) end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; V := array([1 = 4, 2 = 0]); if Digits <= trunc(evalhf(Digits)) then L := Vector(4, 'datatype' = 'float'[8]); yout := Vector(4, 'datatype' = 'float'[8]); evalhf(`dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, var(yout), var(L), var(V))) else L := Vector(4, 'datatype' = 'sfloat'); yout := Vector(4, 'datatype' = 'sfloat'); `dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, yout, L, V) end if; [y = outpoint, seq('[sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)]'[i] = yout[i], i = 1 .. 4)] end proc; if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "method" then return "bvp" elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then return eval(errproc) elif outpoint = "rawdata" then return [4, 8, "depnames", X, Y, YP] else error "non-numeric value" end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; if Digits <= trunc(evalhf(Digits)) and (_EnvInFsolve <> true or _EnvDSNumericSaveDigits <= trunc(evalhf(Digits))) then V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0, (3, 1) = .0, (3, 2) = .0, (4, 1) = .0, (4, 2) = .0, (5, 1) = .0, (5, 2) = .0, (6, 1) = .0, (6, 2) = .0, (7, 1) = .0, (7, 2) = .0}, datatype = float[8], order = C_order); yout := Vector(4, {(1) = .0, (2) = .0, (3) = .0, (4) = .0}, datatype = float[8]); evalhf(`dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, var(yout), var(L), var(V))) else if _EnvInFsolve = true then Digits := _EnvDSNumericSaveDigits end if; V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = 0., (1, 2) = 0., (2, 1) = 0., (2, 2) = 0., (3, 1) = 0., (3, 2) = 0., (4, 1) = 0., (4, 2) = 0., (5, 1) = 0., (5, 2) = 0., (6, 1) = 0., (6, 2) = 0., (7, 1) = 0., (7, 2) = 0.}, order = C_order); yout := Vector(4, {(1) = 0., (2) = 0., (3) = 0., (4) = 0.}); `dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, yout, L, V) end if; [outpoint, seq(yout[i], i = 1 .. 4)] end proc, (2) = Array(1..5, {(1) = 18446746401092086174, (2) = 18446746401092086614, (3) = 18446746401092086790, (4) = 18446746401092086966, (5) = 18446746401092087142}), (3) = [y, sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], (4) = 0}); _solnproc := _dat[1]; if member(y, ["last", 'last']) then _res := _solnproc("last"); if type(_res, 'list') then return _res[1] end if elif type(y, `=`) and member(lhs(y), ["initial", 'initial']) then if type(rhs(y), 'list') then _res := _solnproc("initial" = [0, op(rhs(y))]) else _res := _solnproc("initial" = [1, rhs(y)]) end if; if type(_res, 'list') then return _res[1] end if elif y = "sysvars" then return _dat[3] end if; y end proc, sigma(y) = proc (y) local res, data, solnproc, `sigma(y)`, outpoint; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then outpoint := evalf[_EnvDSNumericSaveDigits](y) else outpoint := evalf(y) end if; data := Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); YP := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = -.0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = -.0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = -.0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = -.0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = -.0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = -.0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = -.0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = -.0}, datatype = float[8], order = C_order); errproc := proc (x_bvp) local outpoint, X, Y, yout, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; Digits := 15; outpoint := evalf(x_bvp); X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then error "this is already the error procedure" elif outpoint = "rawdata" then return [4, 8, [sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], X, Y] else return ('procname')(x_bvp) end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; V := array([1 = 4, 2 = 0]); if Digits <= trunc(evalhf(Digits)) then L := Vector(4, 'datatype' = 'float'[8]); yout := Vector(4, 'datatype' = 'float'[8]); evalhf(`dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, var(yout), var(L), var(V))) else L := Vector(4, 'datatype' = 'sfloat'); yout := Vector(4, 'datatype' = 'sfloat'); `dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, yout, L, V) end if; [y = outpoint, seq('[sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)]'[i] = yout[i], i = 1 .. 4)] end proc; if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "method" then return "bvp" elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then return eval(errproc) elif outpoint = "rawdata" then return [4, 8, "depnames", X, Y, YP] else error "non-numeric value" end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; if Digits <= trunc(evalhf(Digits)) and (_EnvInFsolve <> true or _EnvDSNumericSaveDigits <= trunc(evalhf(Digits))) then V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0, (3, 1) = .0, (3, 2) = .0, (4, 1) = .0, (4, 2) = .0, (5, 1) = .0, (5, 2) = .0, (6, 1) = .0, (6, 2) = .0, (7, 1) = .0, (7, 2) = .0}, datatype = float[8], order = C_order); yout := Vector(4, {(1) = .0, (2) = .0, (3) = .0, (4) = .0}, datatype = float[8]); evalhf(`dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, var(yout), var(L), var(V))) else if _EnvInFsolve = true then Digits := _EnvDSNumericSaveDigits end if; V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = 0., (1, 2) = 0., (2, 1) = 0., (2, 2) = 0., (3, 1) = 0., (3, 2) = 0., (4, 1) = 0., (4, 2) = 0., (5, 1) = 0., (5, 2) = 0., (6, 1) = 0., (6, 2) = 0., (7, 1) = 0., (7, 2) = 0.}, order = C_order); yout := Vector(4, {(1) = 0., (2) = 0., (3) = 0., (4) = 0.}); `dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, yout, L, V) end if; [outpoint, seq(yout[i], i = 1 .. 4)] end proc, (2) = Array(1..5, {(1) = 18446746401092086174, (2) = 18446746401092086614, (3) = 18446746401092086790, (4) = 18446746401092086966, (5) = 18446746401092087142}), (3) = [y, sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], (4) = 0}); solnproc := data[1]; if not type(outpoint, 'numeric') then if outpoint = "solnprocedure" then return eval(solnproc) elif member(outpoint, ["start", "left", "right", "errorproc", "rawdata", "order", "error"]) then return solnproc(y) elif outpoint = "sysvars" then return data[3] elif procname <> unknown then return ('procname')(y) else `sigma(y)` := pointto(data[2][2]); return ('`sigma(y)`')(y) end if end if; try res := solnproc(outpoint); res[2] catch: error  end try end proc, diff(sigma(y), y) = proc (y) local res, data, solnproc, `diff(sigma(y),y)`, outpoint; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then outpoint := evalf[_EnvDSNumericSaveDigits](y) else outpoint := evalf(y) end if; data := Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); YP := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = -.0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = -.0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = -.0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = -.0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = -.0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = -.0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = -.0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = -.0}, datatype = float[8], order = C_order); errproc := proc (x_bvp) local outpoint, X, Y, yout, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; Digits := 15; outpoint := evalf(x_bvp); X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then error "this is already the error procedure" elif outpoint = "rawdata" then return [4, 8, [sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], X, Y] else return ('procname')(x_bvp) end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; V := array([1 = 4, 2 = 0]); if Digits <= trunc(evalhf(Digits)) then L := Vector(4, 'datatype' = 'float'[8]); yout := Vector(4, 'datatype' = 'float'[8]); evalhf(`dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, var(yout), var(L), var(V))) else L := Vector(4, 'datatype' = 'sfloat'); yout := Vector(4, 'datatype' = 'sfloat'); `dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, yout, L, V) end if; [y = outpoint, seq('[sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)]'[i] = yout[i], i = 1 .. 4)] end proc; if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "method" then return "bvp" elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then return eval(errproc) elif outpoint = "rawdata" then return [4, 8, "depnames", X, Y, YP] else error "non-numeric value" end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; if Digits <= trunc(evalhf(Digits)) and (_EnvInFsolve <> true or _EnvDSNumericSaveDigits <= trunc(evalhf(Digits))) then V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0, (3, 1) = .0, (3, 2) = .0, (4, 1) = .0, (4, 2) = .0, (5, 1) = .0, (5, 2) = .0, (6, 1) = .0, (6, 2) = .0, (7, 1) = .0, (7, 2) = .0}, datatype = float[8], order = C_order); yout := Vector(4, {(1) = .0, (2) = .0, (3) = .0, (4) = .0}, datatype = float[8]); evalhf(`dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, var(yout), var(L), var(V))) else if _EnvInFsolve = true then Digits := _EnvDSNumericSaveDigits end if; V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = 0., (1, 2) = 0., (2, 1) = 0., (2, 2) = 0., (3, 1) = 0., (3, 2) = 0., (4, 1) = 0., (4, 2) = 0., (5, 1) = 0., (5, 2) = 0., (6, 1) = 0., (6, 2) = 0., (7, 1) = 0., (7, 2) = 0.}, order = C_order); yout := Vector(4, {(1) = 0., (2) = 0., (3) = 0., (4) = 0.}); `dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, yout, L, V) end if; [outpoint, seq(yout[i], i = 1 .. 4)] end proc, (2) = Array(1..5, {(1) = 18446746401092086174, (2) = 18446746401092086614, (3) = 18446746401092086790, (4) = 18446746401092086966, (5) = 18446746401092087142}), (3) = [y, sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], (4) = 0}); solnproc := data[1]; if not type(outpoint, 'numeric') then if outpoint = "solnprocedure" then return eval(solnproc) elif member(outpoint, ["start", "left", "right", "errorproc", "rawdata", "order", "error"]) then return solnproc(y) elif outpoint = "sysvars" then return data[3] elif procname <> unknown then return ('procname')(y) else `diff(sigma(y),y)` := pointto(data[2][3]); return ('`diff(sigma(y),y)`')(y) end if end if; try res := solnproc(outpoint); res[3] catch: error  end try end proc, theta(y) = proc (y) local res, data, solnproc, `theta(y)`, outpoint; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then outpoint := evalf[_EnvDSNumericSaveDigits](y) else outpoint := evalf(y) end if; data := Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); YP := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = -.0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = -.0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = -.0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = -.0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = -.0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = -.0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = -.0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = -.0}, datatype = float[8], order = C_order); errproc := proc (x_bvp) local outpoint, X, Y, yout, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; Digits := 15; outpoint := evalf(x_bvp); X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then error "this is already the error procedure" elif outpoint = "rawdata" then return [4, 8, [sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], X, Y] else return ('procname')(x_bvp) end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; V := array([1 = 4, 2 = 0]); if Digits <= trunc(evalhf(Digits)) then L := Vector(4, 'datatype' = 'float'[8]); yout := Vector(4, 'datatype' = 'float'[8]); evalhf(`dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, var(yout), var(L), var(V))) else L := Vector(4, 'datatype' = 'sfloat'); yout := Vector(4, 'datatype' = 'sfloat'); `dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, yout, L, V) end if; [y = outpoint, seq('[sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)]'[i] = yout[i], i = 1 .. 4)] end proc; if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "method" then return "bvp" elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then return eval(errproc) elif outpoint = "rawdata" then return [4, 8, "depnames", X, Y, YP] else error "non-numeric value" end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; if Digits <= trunc(evalhf(Digits)) and (_EnvInFsolve <> true or _EnvDSNumericSaveDigits <= trunc(evalhf(Digits))) then V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0, (3, 1) = .0, (3, 2) = .0, (4, 1) = .0, (4, 2) = .0, (5, 1) = .0, (5, 2) = .0, (6, 1) = .0, (6, 2) = .0, (7, 1) = .0, (7, 2) = .0}, datatype = float[8], order = C_order); yout := Vector(4, {(1) = .0, (2) = .0, (3) = .0, (4) = .0}, datatype = float[8]); evalhf(`dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, var(yout), var(L), var(V))) else if _EnvInFsolve = true then Digits := _EnvDSNumericSaveDigits end if; V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = 0., (1, 2) = 0., (2, 1) = 0., (2, 2) = 0., (3, 1) = 0., (3, 2) = 0., (4, 1) = 0., (4, 2) = 0., (5, 1) = 0., (5, 2) = 0., (6, 1) = 0., (6, 2) = 0., (7, 1) = 0., (7, 2) = 0.}, order = C_order); yout := Vector(4, {(1) = 0., (2) = 0., (3) = 0., (4) = 0.}); `dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, yout, L, V) end if; [outpoint, seq(yout[i], i = 1 .. 4)] end proc, (2) = Array(1..5, {(1) = 18446746401092086174, (2) = 18446746401092086614, (3) = 18446746401092086790, (4) = 18446746401092086966, (5) = 18446746401092087142}), (3) = [y, sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], (4) = 0}); solnproc := data[1]; if not type(outpoint, 'numeric') then if outpoint = "solnprocedure" then return eval(solnproc) elif member(outpoint, ["start", "left", "right", "errorproc", "rawdata", "order", "error"]) then return solnproc(y) elif outpoint = "sysvars" then return data[3] elif procname <> unknown then return ('procname')(y) else `theta(y)` := pointto(data[2][4]); return ('`theta(y)`')(y) end if end if; try res := solnproc(outpoint); res[4] catch: error  end try end proc, diff(theta(y), y) = proc (y) local res, data, solnproc, `diff(theta(y),y)`, outpoint; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; _EnvDSNumericSaveDigits := Digits; Digits := 15; if _EnvInFsolve = true then outpoint := evalf[_EnvDSNumericSaveDigits](y) else outpoint := evalf(y) end if; data := Array(1..4, {(1) = proc (outpoint) local X, Y, YP, yout, errproc, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); YP := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = -.0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = -.0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = -.0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = -.0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = -.0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = -.0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = -.0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = -.0}, datatype = float[8], order = C_order); errproc := proc (x_bvp) local outpoint, X, Y, yout, L, V, i; option `Copyright (c) 2000 by Waterloo Maple Inc. All rights reserved.`; Digits := 15; outpoint := evalf(x_bvp); X := Vector(8, {(1) = .0, (2) = .1428571428571428, (3) = .2857142857142856, (4) = .4285714285714285, (5) = .5714285714285715, (6) = .7142857142857144, (7) = .8571428571428572, (8) = 1.0}, datatype = float[8], order = C_order); Y := Matrix(8, 4, {(1, 1) = .0, (1, 2) = .0, (1, 3) = .0, (1, 4) = .0, (2, 1) = .0, (2, 2) = .0, (2, 3) = .0, (2, 4) = .0, (3, 1) = .0, (3, 2) = .0, (3, 3) = .0, (3, 4) = .0, (4, 1) = .0, (4, 2) = .0, (4, 3) = .0, (4, 4) = .0, (5, 1) = .0, (5, 2) = .0, (5, 3) = .0, (5, 4) = .0, (6, 1) = .0, (6, 2) = .0, (6, 3) = .0, (6, 4) = .0, (7, 1) = .0, (7, 2) = .0, (7, 3) = .0, (7, 4) = .0, (8, 1) = .0, (8, 2) = .0, (8, 3) = .0, (8, 4) = .0}, datatype = float[8], order = C_order); if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then error "this is already the error procedure" elif outpoint = "rawdata" then return [4, 8, [sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], X, Y] else return ('procname')(x_bvp) end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; V := array([1 = 4, 2 = 0]); if Digits <= trunc(evalhf(Digits)) then L := Vector(4, 'datatype' = 'float'[8]); yout := Vector(4, 'datatype' = 'float'[8]); evalhf(`dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, var(yout), var(L), var(V))) else L := Vector(4, 'datatype' = 'sfloat'); yout := Vector(4, 'datatype' = 'sfloat'); `dsolve/numeric/lagrange`(8, 4, X, Y, outpoint, yout, L, V) end if; [y = outpoint, seq('[sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)]'[i] = yout[i], i = 1 .. 4)] end proc; if not type(outpoint, 'numeric') then if outpoint = "start" or outpoint = "left" then return X[1] elif outpoint = "method" then return "bvp" elif outpoint = "right" then return X[8] elif outpoint = "order" then return 2 elif outpoint = "error" then return HFloat(-0.0) elif outpoint = "errorproc" then return eval(errproc) elif outpoint = "rawdata" then return [4, 8, "depnames", X, Y, YP] else error "non-numeric value" end if end if; if outpoint < X[1] or X[8] < outpoint then error "solution is only defined in the range %1..%2", X[1], X[8] end if; if Digits <= trunc(evalhf(Digits)) and (_EnvInFsolve <> true or _EnvDSNumericSaveDigits <= trunc(evalhf(Digits))) then V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = .0, (1, 2) = .0, (2, 1) = .0, (2, 2) = .0, (3, 1) = .0, (3, 2) = .0, (4, 1) = .0, (4, 2) = .0, (5, 1) = .0, (5, 2) = .0, (6, 1) = .0, (6, 2) = .0, (7, 1) = .0, (7, 2) = .0}, datatype = float[8], order = C_order); yout := Vector(4, {(1) = .0, (2) = .0, (3) = .0, (4) = .0}, datatype = float[8]); evalhf(`dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, var(yout), var(L), var(V))) else if _EnvInFsolve = true then Digits := _EnvDSNumericSaveDigits end if; V := array( 1 .. 6, [( 1 ) = (7), ( 2 ) = (0), ( 3 ) = (false), ( 4 ) = (false), ( 5 ) = (false), ( 6 ) = (false)  ] ); L := Matrix(7, 2, {(1, 1) = 0., (1, 2) = 0., (2, 1) = 0., (2, 2) = 0., (3, 1) = 0., (3, 2) = 0., (4, 1) = 0., (4, 2) = 0., (5, 1) = 0., (5, 2) = 0., (6, 1) = 0., (6, 2) = 0., (7, 1) = 0., (7, 2) = 0.}, order = C_order); yout := Vector(4, {(1) = 0., (2) = 0., (3) = 0., (4) = 0.}); `dsolve/numeric/hermite`(8, 4, X, Y, YP, outpoint, yout, L, V) end if; [outpoint, seq(yout[i], i = 1 .. 4)] end proc, (2) = Array(1..5, {(1) = 18446746401092086174, (2) = 18446746401092086614, (3) = 18446746401092086790, (4) = 18446746401092086966, (5) = 18446746401092087142}), (3) = [y, sigma(y), diff(sigma(y), y), theta(y), diff(theta(y), y)], (4) = 0}); solnproc := data[1]; if not type(outpoint, 'numeric') then if outpoint = "solnprocedure" then return eval(solnproc) elif member(outpoint, ["start", "left", "right", "errorproc", "rawdata", "order", "error"]) then return solnproc(y) elif outpoint = "sysvars" then return data[3] elif procname <> unknown then return ('procname')(y) else `diff(theta(y),y)` := pointto(data[2][5]); return ('`diff(theta(y),y)`')(y) end if end if; try res := solnproc(outpoint); res[5] catch: error  end try end proc]
Download y.mw
