Question: Physics Package: How to define bracketrules for disjointed/combined spaces?
with the Physics package, I want to represent a discrete two-dimensional Hilbert space in a direct-product basis.
I have looked at https://www.mapleprimes.com/posts/209099-Tensor-Product-Of-Quantum-State-Spaces but am not sure how to implement bracketrules.
Let's assume I have one-dimensional bases A and B that span a two-dimensional space C. A is of size Na and B is of size Nb. Consequently, C is of size Na * Nb.
If I understand it correclty, this can be done with
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C})
First question: Is this correct and if yes, why do I need to specify quantumbasisdimension for C?
Then, I want to define, using bracketrules, <A[i]| <B[j]| |Psi> = X[i,j],
where |Psi> lives in the full, two-dimensional space C and X is a matrix.
<B[j]|Psi> would be a state living in A and <A[i]||Psi> would be a state in B.
How do I define this?
bracketrules = {%Bracket(Bra(A, i)*Bra(B, j), Ket(C, t)) = X[i,j](t)}
gives me an error.
I found a way using the nested expression
bracketrules = {%Bracket(Bra(A, i), Ket(A, j)) = X[i,j], %Bracket(Bra(B, j), Ket(C)) = Ket(A, j)}
giving
Bracket(Bra(A, i), Bracket(Bra(B, j), Ket(C, t))) = X[i,j]
but this is error prone, clumsy and only works in one direction:
Bracket(Bra(B, j), Bracket(Bra(A, i), Ket(C)))
does not work. Of course, I could also specify rules for the reverse direction but this is quite an effort for higher-dimensional spaces (I have, e.g., 9-dimensional spaces in mind).
So how do I do this properly?
Please have a look at the attached example, where I also included time-dependence.
Thanks,
Henrik
First try
restart; restart, with(Physics)
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}, bracketrules = {%Bracket(Bra(A, i)*Bra(B, j), Ket(C, t)) = X[i, j](t)})
Error, (in Physics:-Setup) expected first argument in the Bracket defining a bracket rule to be a 'Bra'; received: Physics:-`*`(%Bra(A, i), %Bra(B, j))
Second try
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}, bracketrules = {%Bracket(Bra(A, i), Bra(B, j), Ket(C, t)) = X[i, j](t)})
[bracketrules = {%Bracket(%Bra(A, i), %Bra(B, j), %Ket(C, t)) = X[i, j](t)}, disjointedspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}]
Physics:-`*`(Physics:-Bra(A, i), Physics:-Bra(B, j), Physics:-Ket(C, t))
Third try
Setup(hilbertspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}, bracketrules = {%Bracket(Bra(A, i), Ket(A, j, t)) = X[i, j](t), %Bracket(Bra(B, j), Ket(C, t)) = Ket(A, j, t)})
[bracketrules = {%Bracket(%Bra(A, i), %Ket(A, j, t)) = X[i, j](t), %Bracket(%Bra(B, j), %Ket(C, t)) = Physics:-Ket(A, j, t)}, disjointedspaces = {{A, C}, {B, C}}, quantumbasisdimension = {A = 1 .. Na, B = 1 .. Nb, C = 1 .. Na*Nb}, quantumdiscretebasis = {A, B, C}]
Bracket(Bra(A, i).Bra(B, j), Ket(C, t))
X[i, j](t)
Bracket(Bra(B, j), Bracket(Bra(A, i), Ket(C, t)))
Error, (in Physics:-Bracket) expected a Bra and a Ket as a first and last arguments, or no Bra and no Ket when using the shortcut notation; received: Physics:-Bra(B,j), Physics:-Bracket(Physics:-Bra(A,i),Physics:-Ket(C,t))
Download twoD.mw
