Question: Sequence data from data file
I'm trying to make a Least-Squares curve fitting plot.  I need to sequence two rows from a data file I imported (see attached worksheet GR10_20190130_PSA_TESTS.mw).  More specifically, I need to sequence the data in
X:=Row(T,1) with the data in y:=Row(T,2).  It should look like
([41115.0,6.97],[41257.0,18.9],[41270.0,15.67]...[43495.0,4.06]) when complete.  I tried seq[X_k,Y_k], that didn't work.  Also tried using an index of 1 to 25 (the number of elements in each row), that didn't work.  Any help with this appreciated, thanks in advance!
Les
