Question: Problem with graphics when using eBookTools
I'm using the eBookTools package to convert a .mw file as a chapter into a PDF file. However, a problem arises when I convert a document with a few repeated plotting commands (such as plot(x^2)). The issue is that in the final PDF the images of the various plots overlap, and that the individual plots can't be clearly seen. Is there a resolution to this?
Thanks,
Bart
