Question: Big MapleSim model can't be totaly simplified
I use MapleSim to model the dynamics of motorcycles.
I have been at MapleSim2018 for a few months and I have a problem of simplifying the equations generated by MapleSim from my model.
In MapleSim2018, he tells me:
Processing Equations...
SelectCompiler: Check for installed compiler successful
Simplifying system with 8919 equations
DSN/ix1lite: Warning, equation size increased past 100000 while performing equation simplification. Model will be simulated in partially unsimplified form
Simplification removed 8428 equations. Remaining equations: 491
Generating simulation code
the same model (exactly the same) in MapleSim2016, he tells me :
Simplifying system with 8942 equations
Simplification removed 8494 equations. Remaining equations: 448
When I generate code from two versions of Maple (2016 and 2018) and compile it into an executable, the MapleSim 2018 executable runs 20% slower than the MapleSim 2016 version of the executable (the results and the behavior of both models are equivalent)
It is very strange that a new version of MapleSim generates a slower code than the old version. it may be due to the limitation of DSN / ix1lite in MapleSim2018 ... while MapleSim2016 does not have this limitation (with more equations to simplify!).
I need help, if it is possible to activate the complete simplification in DSN / ix1lite?
it is a big problem for me, the use of MapleSim2018 is not possible because of that. My model does not pass in real time.
thanks.
