Question: How to remove summation from both sides?
At a point in a worksheet I end up with an equation that has summations on both sides.  The range of summation is the same but the summands are different.  I want to remove the summations from both sides, keeping the equation with just the summands. How can this be done?  The only way I have found is to manually select each summand with the mouse and paste it into a new line which breaks the 'automation' of the script.
Thanks in advance.
