Question: how do i solve it ?
please where is the problem
with(DEtools);
eq1 := (D(x))(t) = -y(t);
eq2 := (D(y))(t) = x(t)+2*x(t)^3-signum(z(t));
eq3 := (D(z))(t) = w(t);
eq4 := (D(w))(t) = -z(t)*(1+6*x(t)^2);
sys := eq1, eq2, eq3, eq4;
ic1 := [x(0) = 0, y(0) = 0, z(0) = cos(1), w(0) = sin(1)];
ic2 := [x(0) = 0, y(0) = 0, z(0) = cos(2.5), w(0) = sin(2.5)];
ic := ic1, ic2;
DEplot([sys], [x(t), y(t), z(t), w(t)], t = 0 .. 10, [ic], stepsize = 0.5e-1, scene = [x(t), y(t)], linecolor = [blue, red]);
sol1:=dsolve({sys,x(0)=0,y(0)=0,z(0)=cos(1),w(0)=sin(1)},{x(t),y(t),z(t),w(t)},type=numeric);
T := 10.0 ; N := 100 ; h := T/N;
xk := 0;
for k from 1 to N do
 solk := sol1(k*h);
  xknew := subs(solk,x(t));
 yknew := subs(solk,y(t));
 if xk*xknew<=0 and abs(yknew-6)<0.5 then break fi;
 xk := xknew;
od; sol1(k*h);
temps := proc(alpha,eps)
local sol,solk,T,N,h,k,xk,xknew,yknew,t0,t1,tm,x0,x1,xm;
sol := dsolve({sys,x(0)=0,y(0)=0,z(0)=cos(alpha),w(0)=sin(alpha)},{x(t),y(t),z(t),w(t)},type=numeric);
xk := 0;
 solk := sol(k*h);
 xk := xknew;
od;
t0 := (k-1)*h ; t1 := k*h ;
x0 := subs(sol(t0),x(t)) ; x1 := subs(sol(t1),x(t)) ;
while abs(x0-x1)>eps do
 tm := (t0+t1)/2;
 xm := subs(sol(tm),x(t));
 if xm*x0<0 then x1 := xm; t1:=tm;
            else x0 := xm; t0:=tm;
 fi;
od;
RETURN(t0);
end;
dicho := proc(eps)
local a,b,m,sola,solb,solm,ta,tb,tm,ya,yb,ym;
a := 1 ; b := 2.5 ;
sola := dsolve({sys,x(0)=0,y(0)=0,z(0)=cos(a),w(0)=sin(a)},{x(t),y(t),z(t),w(t)},type=numeric);
solb := dsolve({sys,x(0)=0,y(0)=0,z(0)=cos(b),w(0)=sin(b)},{x(t),y(t),z(t),w(t)},type=numeric);
ta := temps(a,eps) ; tb := temps(b,eps) ;
ya := subs(sola(ta),y(t)) ; yb := subs(solb(tb),y(t)) ;
while abs(yb-ya)>eps do
m := evalf((a+b)/2);
solm := dsolve({sys,x(0)=0,y(0)=0,z(0)=cos(m),w(0)=sin(m)},{x(t),y(t),z(t),w(t)},type=numeric);
tm := temps(m,eps) ;
yb := subs(sol(tm),y(t));
 if (ym-6)*(ya-6)<0 then b := m; yb := ym;
            else a := m; ya := ym;
 fi;
od;
RETURN(a);
end;
dicho(0.01);
2.136718750
temps(2.136718750,0.01);
8.737500000
DEplot([sys], [x(t), y(t), z(t), w(t)], t = 0 .. 8.7375, [[x(0)=0,y(0)=0,z(0)=cos(2.136718750),w(0)=sin(2.136718750)]], stepsize = 0.5e-1, scene = [x(t), y(t)], linecolor = [blue]);
Error, (in dsolve/numeric/process_input) system must be entered as a set/list of expressions/equations
