Question: Bug in my Division by Zero Calculator
Basically it spits out the subset of values for which a division by zero error will occur for the function you specify on  range you specify for each of it's arguments, but I get an ambigous error when ever exponentiation features in the function I specify, which of course dramatically reduces the application of the calculator. Division,addition,substraction and multiplication are currently the only available arithmetic operators availble for the function window that I know the error will not occur.
If some one can help it is much appriciated
DIVISION_BY_ZERO_CALCULATOR.mw
